Tires are cupped on the inside...anyway even them out?
I guess my alignment messed up my daily driven tires (Kumho 712). The tires still have real good tread all around but the insides are a bit slick (cupped). I was wondering if I ran them with a bit less air pressure causing the tire to lie down a bit more on the pavement, would this help even out the tire over time?
Re: Tires are cupped on the inside...anyway even them out? (RATEDR)
TJ - sounds like you over-filled the tires, if you cupped them. I would just lower the pressure and do mad donuts.
Re: Tires are cupped on the inside...anyway even them out? (Cosworth)
i always run 34psi in the kum-hoes. What should I be running?
I Guess mad burnouts are in my future!
then do some *mad* burnouts
Will
