Third to second downshift issue
Old Nov 4, 2008 | 02:28 PM
mstewar's Avatar
Default Third to second downshift issue
Similar to Black R's issue a couple years ago ( https://honda-tech.com/zerothread?id=1433747 ), except that mine is all the time - hot or cold doesn't matter. Not moving, it will cycle through fine, upshifts are all smooth as silk. Downshifts are all fine except for 3rd->2nd. It just won't go into gear at all 99% of the time, with the exception of every once in awhile where it feels like it just barely goes in. Rev matching, double clutching, and GM Synchromesh have all not changed a thing.
Any thoughts? Bent fork or clearances or something? Trans has to come out to replace the main seal soon so I am trying to figure out what needs to be done to fix it while it's out.
Thanks!
Old Nov 4, 2008 | 03:23 PM
BlueIntegraBoy's Avatar
Default Re: Third to second downshift issue (mstewar)
I have the same problem, but I can get into 2nd if I put it slightly into 1st then back down. I was suggested it to be a mount/bracket problem. I owner I bought the car from said the rear mount needed replacing, but I never did.
Old Nov 4, 2008 | 07:55 PM
Root of all Evil's Avatar
Sometimes you must hate that ****. You can feel when it's going to be a bitch and you can smash it extra hard. Works for 1 month.
Old Nov 5, 2008 | 03:30 AM
walker111's Avatar
Default Re: (Root of all Evil)
I would think a bent shift fork
Old Nov 5, 2008 | 02:38 PM
mstewar's Avatar
Default Re: Third to second downshift issue (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem, but I can get into 2nd if I put it slightly into 1st then back down. I was suggested it to be a mount/bracket problem. I owner I bought the car from said the rear mount needed replacing, but I never did.</TD></TR></TABLE>
yeah, the same thing will work for me.. odd that it would be a mount.. this happens at low torque load and there isn't much engine twisting going on..
Old Nov 6, 2008 | 09:07 PM
BlueStar's Avatar
i have the same problem..But for me it also gets stuck in reverse, i have to almost force it out. all my gears are smooth upshifting but even when i try to down shift to 2nd from 3rd at even 10mph or lower it still doesnt go in. its getting anoying.
Old Nov 14, 2008 | 11:08 AM
mstewar's Avatar
anyone have a suggestion on where to send the trans out to? King? Elsewhere?
I am not planning to try and split it and figure this out.
Old Nov 14, 2008 | 11:34 AM
Dave_B's Avatar
Send it to me, I'll rip it open/fix and send back.
Old Nov 14, 2008 | 11:49 AM
The Dude's Avatar
Banned
Yeah I had a busted M.M. and it does affect the shifting and loading did not seem to make a difference. But if it's that bad it may be a bent fork or something.
FYI, had KING rebuild and I think they replaced 3rd fork and replaced all mounts with Mugens and WOW! Better than new.
Modified by The Dude at 2:57 PM 11/14/2008
Old Nov 14, 2008 | 12:10 PM
Aquafina's Avatar
Doubt its a fork since it upshifts fine. More than likely the hub/slider. Feel free to send it to me. Can upgrade while we're in there if you want to.
Old Dec 5, 2008 | 11:11 AM
mstewar's Avatar
In case anyone is interested, it turned out to be the 1-2 synchro.. all fixed now!
Old Dec 5, 2008 | 12:45 PM
get RIGHT's Avatar
Good to hear.
Old Dec 5, 2008 | 11:08 PM
Dang EG's Avatar
Who did the work for you if I may ask? I have the same problem right now. The transmission is tough when it is cold but once the temperature is at operating conditions, it gets easier.
loco4sho2004
Aug 16, 2008 11:59 AM
StolenTeg
Apr 27, 2008 02:56 PM
inane
20
Feb 21, 2005 03:04 AM
H-TownHonda
Jul 2, 2004 09:53 AM
