tech ???
Old May 25, 2010 | 03:37 PM
dmxbmx's Avatar
Default tech ???
alright so i have a new problem with the car.
i go to start it and it shuts right off. i proceed to give it a little gas and then try and start it and it will start but it sputters like 1 or 2 cylanders is misfiring and after about 5 or 10 seconds it smooths out and runs fine.
im thinking ecu or distrubitor.
anyone else experience this?
Old May 25, 2010 | 03:50 PM
Tyrant_007's Avatar
Default Re: tech ???
I've had similar symptoms when the ignitor in my distributor was going out. Does it do this when the car is cold, or after it had been running and shut off?
Old May 25, 2010 | 04:39 PM
dmxbmx's Avatar
only when cold. once its warms up no problems i can shut it on and off with no problems. i can even let it sit for like 30min to and hour and no problems.
it only does it if its been sitting for awhile
Old May 25, 2010 | 06:32 PM
uNF$@#!'s Avatar
alternator?
Old May 26, 2010 | 01:32 AM
Gabe87CRX's Avatar
Originally Posted by uNF$@#!
alternator?
+1
Old May 26, 2010 | 06:17 AM
LankorDie's Avatar
Loved
Community Favorite
Ohm out your ignitor and coil in your distributor. Are you using any non OEM Honda parts in your ingition system?
Old May 26, 2010 | 03:47 PM
dmxbmx's Avatar
oem honda everything except for msd wires.
what i noticed is...... it only does it at night once the sun goes down.
but if the suns up i dont have any problems.
wtf?
Old May 26, 2010 | 06:09 PM
LankorDie's Avatar
Loved
Community Favorite
You could have a small crack in your ignitor or coil. When its cold the crack is bigger and causes the problem, when it is hot the material would expand, close the crack and you would not have the problem.
Can you use a buddys dizzy for a few days and see if you no long have the problem?
Old May 26, 2010 | 10:41 PM
collin-eg2's Avatar
Yeah use a substitute dizzy
Old May 27, 2010 | 05:01 AM
dmxbmx's Avatar
yea ill just try the dizzy off my eg6 gotta make a obd2 to obd1 harness though
crx_si-r
Nov 12, 2008 06:41 PM
BlitzSix
Dec 9, 2006 11:49 PM
Quade
Oct 27, 2004 11:29 AM
Tru_Hybrid
Nov 6, 2003 06:44 AM
mjb240z
Apr 10, 2002 06:27 PM
