starting problems
Old Jun 25, 2001 | 07:43 PM
itr0032's Avatar
Default starting problems
Some days my car turns over a little longer then normal (like 5-7 sec).Does anyone ever have this problem?I was hoping it was bad gas but it have happened quite a few times .....
Old Jun 25, 2001 | 07:46 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: starting problems (itr0032)
Low on gas? My car does that when I have less than 1/4-1/8 of a tank.
Old Jun 25, 2001 | 07:47 PM
yellow blur's Avatar
Default Re: starting problems (itr009)
i've had the same problem when it wouldn't turn over the first time, now i just stick the key in, and turn it to on, and wait until all the lights flash and the noises finish, then crank it over. even with less than 1/4 of a tank it starts the first time most of the time. give this a try.
Old Jun 25, 2001 | 07:51 PM
SamB's Avatar
New User
Default Re: starting problems (yellow blur)
Souns like the old low fuel level problem. When its low on gas let the fuel pump run for a few seconds, this should help. If it doesn't I don't know what the problem is
Sam
Old Jun 25, 2001 | 08:15 PM
BlackGSR's Avatar
Default Re: starting problems (Sam & Bridget)
Happens on my GSR. Sometimes it starts fine - while other times it takes 5-7 seconds to start.
Old Jun 25, 2001 | 09:45 PM
Chris's Avatar
Low on gas....
Old Jun 25, 2001 | 09:47 PM
Bob#455's Avatar
Default Re: starting problems (Chris)
Or semi-low on gas and parked on my driveway.
Old Jun 26, 2001 | 02:33 AM
itr0032's Avatar
Default Re: starting problems (Bob#497)
It does it even with a full tank.
Old Jun 26, 2001 | 02:51 AM
Chaze*R's Avatar
I think it is normal because this happens to my R also...and when I had my SI it used to do the same thing...This past saturday my R took a long time to start and when it did the idle was jumpy for a few more seconds then normal...If anyone knows why this is not normal please explain. Thankx
-Chuck-
Old Jun 26, 2001 | 04:22 AM
01r's Avatar
01r
New User
Default Re: starting problems (Chaze*R)
oh boy, i thought i was the only one!!!!!!! it takes long even with a full full tank of gas. it doesnt happen all the time. it seems to happen whenever i have left the car untouched for a few days, maybe a bad starter?? maybe the battery?? or the connections are bad? or maybe even the fuel pump?
i was thinking about bringing it in.....
[Modified by 01r, 8:22 AM 6/26/2001]
Old Jun 26, 2001 | 06:55 AM
briq4's Avatar
Default Re: starting problems (01r)
I think it's a Honda thing. My mom's Accord V-6 does it, and if it doesn't start on the first try then it's REALLY hard to start. My 93 Accord does it, my cousin's 96 Accord does it and a friend of mine has a 1999 Civic Si and it has the same issue. But it has NEVER not started. I can live with it. Also don't even try with the dealer because you know it will start EVERY TIME if you actually take it to them.
Old Jun 26, 2001 | 07:27 AM
R134's Avatar
Mine does the same thing even with a full tank. It only happens when the engine is warmed up.
Old Jun 26, 2001 | 07:32 AM
Digital-R's Avatar
Default Re: starting problems (R134)
Weird; Mine does the same thing but only when its really hot outside like it has been recently. It does not matter if the car is warmed up or cold, just depends on the weather.
Old Jun 26, 2001 | 11:22 AM
itr0032's Avatar
Default Re: starting problems (Digital-R)
Thanks...I feel much better now,that I know I'm not the only one.
Old Jun 26, 2001 | 12:33 PM
FBP_1171's Avatar
Mine would not start at all one day, at the gas station. I pulled the key out, and put it back in, started right up. Could be the chip or receiver.
VTECwalka
20
Jan 28, 2013 07:06 AM
StraightCivic
May 15, 2006 05:07 AM
igo4bmx
May 20, 2005 12:58 PM
pr0digy1
May 8, 2002 09:08 AM
