some input please...
Old Feb 9, 2009 | 08:54 PM
wrinkly's Avatar
Default some input please...
So I am getting ready to take the car out after hibernating it for the winter. just wanted to do some maintenance and wanted some of your opinions
i was thinking:
oil, tranny, steering fluid change
new spark plugs, plug wires and a new cap and rotor.
also thinking of getting valve adjustment and coolant flush
anything else i'm missing? new fuel filter perhaps?
any ideas would be greatly appreciated.
Old Feb 9, 2009 | 09:17 PM
Shawn C's Avatar
In The Garage
Default Re: some input please...
just make sure the plugs and plug wires are ngk
Old Feb 10, 2009 | 06:27 AM
ITR525's Avatar
sorry i dont mean to jack
your thread, i gotta do this also.
where ya plan on getting it done?
Old Feb 10, 2009 | 06:35 AM
9KRevLimitDC2's Avatar
If your having someone do it for you go to a Honda Dealer, if your doing it yourself, use oem parts (except oil if you use synthetic etc..). x2 on the ngk parts as well. Sounds like you covered everything that i would recommend. for doing preventative maintenance
Old Feb 10, 2009 | 09:34 AM
fpvteg0681's Avatar
sounds like more than i would do actually...isnt a valve adjustment a bit much?
Old Feb 10, 2009 | 09:55 AM
nsxtasy's Avatar
H-T Order of Merit
Check your owner's manual or service manual for the recommended service intervals, and compare them with how long it's been since each service was last done. Remember that the intervals are specified in both distance (miles or kilometers) and time, and it's whichever interval comes first.
Old Feb 10, 2009 | 10:53 AM
wrinkly's Avatar
well im not sure...i was under the impression that a valve adjustment should be done every 25k km? also i remember ischijima (guy who owns spoon) saying that "ideally" you should adjust your valves every time after you hit vtec.....
and ITR525, im thinking of either taking it to a local stealership or doing the work myself...
Old Feb 10, 2009 | 11:34 AM
Ed 341's Avatar
Isn't Spoon the local stealership in Tokyo? Whoa.. that just blew my mind!
Old Feb 10, 2009 | 07:33 PM
wrinkly's Avatar
thanks guys for the input...i was thinking of using seafoam as well...but i have read mixed reviews on that.
Old Feb 12, 2009 | 07:18 AM
robfrmny21's Avatar
fresh gas
Old Feb 12, 2009 | 08:14 AM
Dang EG's Avatar
Originally Posted by robfrmny21
fresh gas
You should go and purchase the valve adjustment tool and do it yourself. It is fairly easy and took me about an hour the first time I did it. All you need is patience...
Good luck...
Old Feb 12, 2009 | 10:53 AM
thetunersource's Avatar
Definitely check your seals for any leaks.
tegra96
Mar 26, 2006 05:28 AM
tjohnson329
Jan 11, 2006 07:41 PM
94DOHCDELSOL
20
Apr 12, 2005 08:21 AM
alfaaay
Mar 15, 2004 11:41 PM
JDMlyfestyle
Jan 4, 2004 03:36 PM
