smoke when in VTEC solution?
Old Aug 14, 2014 | 11:08 AM
2dr CRX's Avatar
Lots of smoke in VTEC and burning oil (used half a gallon in 3000miles) I have an idea of the cause (abuse by previous owner/going in to VTEC when engine cold most likely) but what is the solution?
Old Aug 14, 2014 | 11:13 AM
boostjunkie757's Avatar
Default Re: smoke when in VTEC solution?
if its burning a gallon in 3000 miles there could be LOTS of problems..
Old Aug 14, 2014 | 11:25 AM
2dr CRX's Avatar
Such as?
Old Aug 14, 2014 | 11:26 AM
2dr CRX's Avatar
N sorry not a gallon I meant to put half a gallon *facepalm*
Old Aug 14, 2014 | 12:08 PM
purplepassiongsr's Avatar
Do a leak down like he said it could be a bunch of things
Old Aug 14, 2014 | 12:39 PM
Xian's Avatar
Half a gallon is better than a gallon but that's still an awful lot of oil. Compression and Leak Down will start pointing you in the right direction. Any suggestions offered ahead of that are merely that... suggestions on what "could" be wrong. Nearly all of them entail opening up the engine so test things out and then come back with the results.
Old Aug 15, 2014 | 05:20 AM
2dr CRX's Avatar
I plan to open up the engine anyway so shall try these when I do, thanks
Old Aug 15, 2014 | 05:37 AM
2dr CRX's Avatar
Also if it helps the smoke has a blue tint to it
Old Aug 15, 2014 | 07:06 AM
itr#1334's Avatar
Blue tint means it's oil you are burning. My guess is it's your rings. My old type r went through about half a quart every 300 miles. And it's been like that for the last 40k. I never changed the oil just the filter lol.
Old Aug 15, 2014 | 07:15 AM
typer_696's Avatar
Get your head rebuilt. New valve seal guides may need valves. Common issue with these motors after being driven hard continously and high miles. May possibly need new rings as well.
Old Aug 15, 2014 | 08:15 AM
2dr CRX's Avatar
Well the plan is to rebuild full engine, new high comp pistons with rings new gaskets port n polish head new valve spings and retainers new cams new shell bearings and anything else that needs replacing along the way
Old Aug 15, 2014 | 06:27 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
So...we're skipping the compression and leak down test then?
Old Aug 16, 2014 | 06:09 AM
2dr CRX's Avatar
No but I can do that in the process just need to wait for kit to arrive
Old Aug 16, 2014 | 06:11 AM
2dr CRX's Avatar
Unless there is no point? Ive never done compression/leak tests before
Old Aug 17, 2014 | 04:44 PM
Runnerdown's Avatar
Unless there is fairly significant engine damage, compression and leak down will normally still read fine in situations like this. If it's an original engine just rebuild it.
Old Aug 18, 2014 | 11:44 PM
2dr CRX's Avatar
Thanks for the info
balleur
Oct 6, 2007 01:42 PM
JDM00SI
Apr 4, 2005 07:27 AM
fullthrottle35
Nov 3, 2004 09:10 PM
ZCboost
Sep 3, 2004 12:50 PM
Phuc yiu
Jul 16, 2002 01:13 AM
