Should a 2001 ITR have Vin tag on Tranny??
Old 05-30-2005, 04:01 AM
MR Dan's Avatar
Default Should a 2001 ITR have Vin tag on Tranny??
This is a pic of a 2001 ITR. You can see there is no Vin tag on the tranny.
Old 05-30-2005, 04:23 AM
Ill
Ill's Avatar
Default Re: Should a 2001 ITR have Vin tag on Tranny?? (DP24)
I can't tell if it dos or not from the pic.
Yes, it should have a VIN tag on tranny.
:edit: If it's a replacement tranny (new) from Acura, it won't have a tag.
Old 05-30-2005, 06:10 AM
Finland's Avatar
Yep, either it's stolen, or it's a factory replacement tranny.
Old 05-30-2005, 06:41 AM
SecretAgent's Avatar
or it's a JDM swap. they don't have the motor and tranny VIN tags in japan.
Old 05-30-2005, 09:02 AM
MR Dan's Avatar
Default Re: (SecretAgent)
heres a response from the owner:
"Another question. Why is the Vin tag missing from the transmission?? I can see holes where the vin should be attached.."
I have only one answer for that, that's not possible since nothing has been replaced or changed from manufacture. The vin tag is where it should be.
Old 05-30-2005, 01:01 PM
justinsouza's Avatar
Default Re: Should a 2001 ITR have Vin tag on Tranny?? (Ill)
i bought a new one, no vin either, the po-po questions it all the time
Old 05-30-2005, 01:31 PM
dented_EG8's Avatar
Default Re: (DP24)
Is the person you purchased the car from the original owner? If not, its possible that he's telling the truth ruth (at least to his knowledge anyway).
Okay, so the question I have is whether the holes on the transmission are present on JDM, USDM and repleacemetn USDM transmissions?
For the people who have replacements, can you verify if they have predrilled holes?
As for the JDM trannys, I took at my JDM Del SOl Vetec swap and it has a bar code sticker and no holes. So if the tranny or exterior case is from a JDM car, it would not have holes, unless Honda made variations in manufacturing processes over the years.
Now it does seem the U.S. trannys do have tags rivetted on to the case. It would seem you have a U.S. tranny and someone drilled out the rivets for some unknown reason :cough: stealing :cough:
1993sir05's Avatar
Default Re: (DP24)
[/QUOTE]
everyone is correct and the seller is either lying or assuming either way there is supposed to be a vin tag on that tranny.
Old 05-30-2005, 01:55 PM
-tc-'s Avatar
Default Re: (dented_EG8)
i just bought a new one from a acura dealer and it does have the two holes for the vin tag, just no tag it self, so just because the holes for the vin tag are there and there isnt a tag dosn't means it stolen.
Old 05-30-2005, 02:41 PM
B-A-N-N-E-D
B-A-N-A-N-A-S's Avatar
ask him for the code of the tranny to see if its usdm or jdm.
Old 05-30-2005, 04:16 PM
Ill
Ill's Avatar
Default Re: (DP24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DP24 &raquo;</TD></TR><TR><TD CLASS="quote">heres a response from the owner:
I agree .
Find out if he's the original owner, or what the story about the history is.
I don't think any JDM tranny's came with the holes - Only the USDM units. Just like the JDM blocks are stamped B18C, not C5. I think this holds doubly, since JDM tranny's are 4.785 not 4.4 FD ratio like USDM.
Sooooo.... Either he's not the original owner, and the original owner replaced the trans with factory, OR, it's stolen.
Good eyes Mr. poster! Keep it up e-bay Type R po-po!!
Old 05-30-2005, 05:14 PM
caspers_hatch's Avatar
Default Re: (Ill)
Ill...your wrong.
My jdm ITR trans with the 4.7 had holes for a vin tag.
Old 05-30-2005, 05:19 PM
MR Dan's Avatar
Default Re: (caspers_hatch)
2001 USDM ITR tranny has J4D LSD writen on the casing correct??
Heres the link of the ITR thats for sale on Ebay: http://cgi.ebay.com/ebaymotors...&rd=1
Modified by DP24 at 2:47 AM 5/31/2005
Old 05-31-2005, 07:30 AM
Ill
Ill's Avatar
Interesting. Apparently the JDM trans comes with and without VIN tag holes.
Old 05-31-2005, 08:43 AM
B_CRUZ!'s Avatar
Default Re: (Ill)
My tranny looks guilty. I have holes with no vins.... but then again I have a 00 CTR tranny.
wunfstgsr
08-09-2008 01:26 PM
1.8L_allmotormilitia
06-10-2007 01:09 AM
J.nguyen
12-24-2005 05:56 PM
alfee
01-05-2005 04:34 PM
StinkyTofu
12-19-2002 01:07 PM
Quick Reply: Should a 2001 ITR have Vin tag on Tranny??
