Rotating tachometer?
Old Jun 6, 2002 | 10:21 AM
Padawan's Avatar
Darth ModerVader
Default Rotating tachometer?
Is it possible to rotate the tachometer 90 degrees on the stock cluster? I've never taken the cluster apart so I'm not certain how the tach is secured, but I was hoping to be able to remove the screws and rotate the tach so that redline is approximately at the top, then replace the screws. Does anyone have any pics of the back of the cluster or know if this can be done? I'd just rather not take mine apart only to find that my plan won't work.
Old Jun 6, 2002 | 10:22 AM
Cosworth's Avatar
Default Re: Rotating tachometer? (Spec.R 00-0123)
no, it can't be done.
Old Jun 6, 2002 | 10:28 AM
uNF$@#!'s Avatar
Default Re: Rotating tachometer? (Cosworth)
actually, your wrong. it can be done.
Old Jun 6, 2002 | 10:35 AM
uNF$@#!'s Avatar
Default Re: Rotating tachometer? (00-0187)
IM me if you are interested in knowing. I would be more than willing to help.
00-0187
Old Jun 6, 2002 | 10:39 AM
Dave-ROR's Avatar
I'll try to remember to look tonight, but it wouldn't be that simple.. the four screws holding it in all carry power, ground, signal, etc.. the two screws holding the gauge face can only mount the way they are, or at 180 degrees.. I'll try to remember to look at my bling bling JDM ITR cluster (which is sitting outside on the patio chillin) tonight.
Old Jun 6, 2002 | 10:40 AM
uNF$@#!'s Avatar
Default Re: Rotating tachometer? (01_Yeller_ITR)
no need to rotate the actual mechanism, just modify the faceplace, rotate that and recalibrate the needle.
Old Jun 6, 2002 | 10:56 AM
Dave-ROR's Avatar
Modify how? The screw locations are molded into the piece, or would you no longer be using them? Just post the info here, not like this info helps thieves or something.
Supa Troopa
62
Jul 19, 2023 10:07 AM
efjones9
Oct 24, 2009 03:54 AM
anguish
Apr 4, 2004 11:37 AM
Adam.
16
May 4, 2003 02:55 PM
theNewCivicGuy
10
May 2, 2002 03:07 PM
