Quick Q to ask about primary sensor
Old Jan 28, 2007 | 03:42 PM
400WHPITR's Avatar
Default Quick Q to ask about primary sensor
I recently bought and 2000 itr with (b18a) ls/vtec turbo. The car came with a p73 ecu (OBD2 ECU) with an obd1 wiring harness conversion. To make the story short, the MIL light came on and I manage to retrieve dtc code 1 which is the primary o2 sensor. Since the wiring harness is obd1, there was only one 02 sensor being used, located on the downpipe. I was just wondering if anyone can give me advice on which year and model should I look for when ordering the o2 sensor? Any help guys, I try to search but could find that much help on the topic.
Old Jan 28, 2007 | 03:46 PM
neo_'s Avatar
Default Re: Quick Q to ask about primary sensor (400WHPITR)
Not only did you buy an ITR with an LS engine but it is using a stock ITR ECU on an LS/VTEC Turbo setup?
Old Jan 28, 2007 | 03:52 PM
400WHPITR's Avatar
Default Re: Quick Q to ask about primary sensor (neo_)
From what I had heard, the previous owner use a hondata also. Just wondering if you which year and model is the o2 sensor?? U think I should look for 02 sensor for 90-95 ls model??
Old Jan 28, 2007 | 03:55 PM
neo_'s Avatar
So you are saying it has an ODB1 engine wire harness? Either way, this question is better suited in the hybrid forum.
Old Jan 28, 2007 | 03:57 PM
400WHPITR's Avatar
Thanks, let me try the hybrid forum. Thanks for ur help.
400WHPITR
Jan 29, 2007 10:38 AM
Vtec92Civic
Oct 24, 2004 04:35 PM
knowtomorrow3001
Jan 12, 2004 07:41 AM
