pulling error code - did a search
Old Feb 8, 2002 | 05:09 AM
Ex-ITR5874's Avatar
Default pulling error code - did a search
since the power fc is installed, I`ve seen the check engine light 4-5 times just for half a second....
I want to read out the error code. Which wires do I have to connect ?
I did a search but found only some explainations to the codes but not how to pull them.
Thanks
Old Feb 8, 2002 | 05:10 AM
FSTASNTZ's Avatar
Default Re: pulling error code - did a search (Maijk190)
Is it a certain RPM range you are seeing the light flash? The power FC will flash the light for certain things, too much knock is one of them, but not store a code...
Jason
Old Feb 8, 2002 | 05:35 AM
Ex-ITR5874's Avatar
Default Re: pulling error code - did a search (FSTASNTZ)
Hmmm,
I remember the light flashing between 3500 and 6000rpm, midrange, at half throttle.
My tuner asked me to read the error code at the green wire where the ecu sits.. But I don`t know where exactly I have to connect the wires.
Old Feb 8, 2002 | 06:44 AM
Bert's Avatar
This should help...
http://integra.vtec.net/geeser/service_connector.html
Old Feb 8, 2002 | 07:04 AM
FSTASNTZ's Avatar
Default Re: pulling error code - did a search (Bert)
I would bet you have too much timing at that point in the chart. Back off the timing just a bit and see what happens...
When I had the power FC, and was tuning for the first time, it did the same thing for me...
Jason
76 camaro car
May 28, 2011 08:09 AM
skaternak
Oct 29, 2008 01:40 PM
kitboi826
Apr 3, 2005 02:52 PM
Toda Built
Jul 10, 2003 02:46 AM
