Prothane Motor mount users!
Old Sep 16, 2001 | 01:46 AM
RagingAngel's Avatar
Default Prothane Motor mount users!
I got these inserts primarily because I was impressed by the high durometer of the product.
I unfortunately did not install the driver side mount because, from what I know, it entails destroying the liquid filled mount in the process.
So as it stands now, I have the rear mount and side(pass.) mount installed.
My problem is the fact the car lurches quite violently during on/off throttle inputs. Previously when the car would drop below 1500rpm in 2nd gear...I could step on the gas with moderate pressure and the car would pull smoothly....with Prothane, the car would jerk suddenly before getting on its way.
I've never driven anybody elses car with the Prothane inserts....only G3-TEG's car which has the ES bushings (does NOT suffer from this)....I've never adjusted my throttle cable before...it is as loose as it should be on a factory R....
Is this normal?? Or would installing the driver's mount help kill this? I don't notice the harsh vibes like everybody says is prominent but then again I'm running 2/3 mounts.
Old Sep 16, 2001 | 09:49 AM
R134's Avatar
Default Re: Prothane Motor mount users! (RagingAngel)
I'm running all three ES motor mounts. When I drop to 1500rpm the car shakes really bad. The dash shakes violently like when I used to get wheel hop.
Old Sep 16, 2001 | 01:42 PM
SnyperSiR's Avatar
RA: I'm suffering the same problem as you again... But mine is just a crappy off-idle response. Grr...
Old Sep 16, 2001 | 01:49 PM
Big Phat R's Avatar
I just put in all three too. I notice a hell of a lot of vibration now. My CD skips from my clutch engagement vibration.
Old Sep 16, 2001 | 06:57 PM
Mike K's Avatar
Default Re: Prothane Motor mount users! (Big Phat R)
I had the Prothane mounts in my Civic. They were stiff as **** but I didn't like them. Too much vibration for the street.
I have the Mugen mount kit in my Integra. Slight vibration, but barely noticeable.
Nice quality, too.
Old Sep 16, 2001 | 09:04 PM
Rain_man's Avatar
New User
Default Re: Prothane Motor mount users! (Mike K)
Oh really, the Mugen kit isn't that bad? I was considering that kit but will hold off til I'm in Japan so I don't pay 400 dollars...
Old Sep 17, 2001 | 12:59 PM
AW's Avatar
AW
Default Re: Prothane Motor mount users! (Ein)
I had all three prothane motor mounts in my car. I think the problem you have is that the passenger side transmission mount may be broken. The Prothane kit does not replace this mount or even offer an insert. Not sure if the ES kit does either. Checks this mount and replace it if worn. As for the driver side engine mount that is liquid filled. Leave it! The vibrations in my car were so bad that I ended up replacing all the mounts except the rear back to stock. With all three mounts, the car felt awesome at the track but streetability was awful. I shook everything in my car loose including the windshield!!!
Old Sep 17, 2001 | 01:44 PM
Default Re: Prothane Motor mount users! (AW)
after careful consideration of all things posted....
I think I might remove the tranny mount and off it to my friend with a DelSol...since his driver's mount is not liquid filled.
I will opt for the ES lower inserts instead.... in hopes for the same type of response....
Will check for the cracked mount....thanks for the tips guys! Much appreciated!
Old Sep 17, 2001 | 01:59 PM
98TypeR's Avatar
i have the spoon motor mounts. you get all 5 of them. they are supposively stiffer than stock which they are but i can't notice any more vibration. just better throttle response.
komat
Dec 13, 2005 09:48 AM
DeeCeeTwo
Jul 19, 2005 11:32 PM
Haruspex
Feb 19, 2005 08:51 AM
khmboostedeh2
14
Dec 20, 2004 08:16 AM
mattL
May 25, 2004 12:32 PM
