Problem with throttle response.
Old Jan 14, 2002 | 01:58 PM
blazin's Avatar
Default Problem with throttle response.
What would cause the throttle response to be slow?I mean when I push the pedal the response of the engine is hesitant and them overrevs.It's like the engine revs are a second slower then my foot on the pedal.How do I fix.
Old Jan 14, 2002 | 02:08 PM
sgT's Avatar
sgT
Default Re: Problem with throttle response. (blazin)
ignition timing perhaps?
Old Jan 14, 2002 | 05:30 PM
blazin's Avatar
Default Re: Problem with throttle response. (sgT)
Old Jan 14, 2002 | 06:16 PM
Wildohiorice's Avatar
New User
Tighten your Throttle Cable, Its by the intake, there 2 nuts (10mm) i believe, lol whole car is 10mm but loosen 1 so that u can take up the tension, take it up so that when u pull on the cable up it moves slightly then moves the pulley u don't want it so tight that the pulley is getting pulled at idle. Mine was way off and noticed a difference in response when i tighten the cable.
Old Jan 14, 2002 | 06:40 PM
ThePunk's Avatar
Default Re: Problem with throttle response. (Wildohiorice)
Is the car stock?
bk7794
13
Jun 21, 2012 08:17 PM
raidacaipo
Oct 12, 2008 06:42 PM
ricertypeR
Jun 24, 2008 08:44 PM
VTEC-DA
Dec 10, 2002 05:25 PM
Hcivic88
13
Nov 4, 2002 03:36 PM
