Problem with brake indicator light
Old Dec 2, 2003 | 06:02 PM
ITR184's Avatar
Default Problem with brake indicator light
I got a problem with the brake indicator light staying on after I release the e-brake. It will go off after a couple of miles and it usually comes on after the car has been sitting over night or longer. It has also come on while I was cruising down the road. That only happend once or twice. The brake fluid level is Kosher and so is the pad wear. I have 24000 on my ITR. I suspected maybe the E-brake limit switch but since it came on while I was driving I don't believe that is the problem. Just seeing if any one has had this problem. I don't really want to take it to the dealer.
Old Dec 2, 2003 | 06:06 PM
ZygSpeed's Avatar
Default Re: Problem with brake indicator light (Big Bad Boody Dady)
Add more brake fluid. really
Old Dec 2, 2003 | 06:13 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Problem with brake indicator light (zygspeed)
A bad sensor on the brake fluid reservoir cap is not unheard of.
But like Ed said, triple-check your brake fluid level, or add a splash extra.
Old Dec 2, 2003 | 06:14 PM
ITR184's Avatar
Brake Fluid is to the full level.
Old Dec 2, 2003 | 06:16 PM
ITR184's Avatar
Default Re: Problem with brake indicator light (Splat)
How is that sensor normally opened or normally closed? Or does it mesure off of resistance. I will bring home my fluke meter tomorrow and Ohm it out thanks.
Old Dec 2, 2003 | 06:34 PM
ZygSpeed's Avatar
Add some above the full level, but not so much that you make a mess.
Mine is doing the same thing (again), need to add a splash more and maybe giggle the float.
Old Dec 3, 2003 | 05:24 AM
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Bad Boody Dady &raquo;</TD></TR><TR><TD CLASS="quote">How is that sensor normally opened or normally closed? Or does it mesure off of resistance. I will bring home my fluke meter tomorrow and Ohm it out thanks.</TD></TR></TABLE>
I have nooo idea
But I do know it has caused problems for some people. Or do what Ed suggests - add a touch more fluid for a free fix. Save money for
Old Dec 3, 2003 | 05:40 AM
cmdr430's Avatar
i had the same problem on my R's, i just added a little more fluid. i first noticed the light staying on when it turned cold outside, never during the summer months. the light would go out after the fluid got a little warm and expanded. not a big problem, easy fix.
bradtricker
11
May 19, 2009 01:32 PM
hatch96y7
Oct 26, 2007 08:08 AM
low430
Oct 30, 2005 01:02 AM
Tench
May 11, 2004 10:23 AM
type r 01-1063
Apr 3, 2003 11:04 PM
