oil leak need help
oil leak need help
its ether coming from the cam seal,o-ring on the dizz or v-tec solinoid.my v-tec isnt working now probley because of this leak?any ideas?
Re: oil leak need help (jdm ek9 101)
first.....check the valve cover seal and check your oil pan........most common places for oil leak (if high mileage ) due to gaskes wearing out.....if those are ok....make sure your plugs aren't oily
Vtec isnt working because your oil pressure is low, but as for the leak..... ive had this problem with many b-series. Check where diversegsr said first, then if still no luck, it may be the head gasket. The gasket may still seal the cylinders, but the outer part may be leaking oil..... good luck
2k2silvertype-s
12-20-2002 07:04 AM
