Oil Drain Plug
Old 09-20-2002, 06:43 AM
WTypeRogerX's Avatar
Default Oil Drain Plug
What size socket wrench do you use to remove the oil drain plug?
Old 09-20-2002, 06:46 AM
Asahi's Avatar
Default Re: Oil Drain Plug (WTypeRogerX)
17mm
Old 09-20-2002, 06:51 AM
Hooch'n's Avatar
Default Re: Oil Drain Plug (Asahi)
Yep.....................torque spec's 25ftpounds.
Andy: Who just does by feel.....Most of the time!
Old 09-20-2002, 07:09 AM
Default Re: Oil Drain Plug (Hooch at 8400-RPM)
What about the plug washer size? Can you just buy the washer at any auto parts or hardware store?
Do I need to buy a special torque wrench to get it torqued to spec?
Old 09-20-2002, 07:14 AM
AssPenny's Avatar
Just do it by feel, if you ever turned a wrench before, you should know. As for the washer, just hit it from honda/acura. They are like 25 cents each.
Old 09-20-2002, 07:15 AM
Chris N's Avatar
I think you can get the washer you need from an acura dealer, when you get your oil filter. I'm not sure of the size.... acura always asks me if I want that washer when i order filters.
Old 09-20-2002, 07:27 AM
rainman's Avatar
Default Re: Oil Drain Plug (1107)
Actually the torque spec is 33 lbft
Old 09-20-2002, 07:42 AM
Bbasso's Avatar
Default Re: Oil Drain Plug (rainman)
use the washer that Honda gives you, Its a crush washer and seals very nice and be sure to only use once or twice.
Old 09-23-2002, 10:11 PM
Default Re: Oil Drain Plug (Bbasso)
How the hell do you guys get jack stands under the car? The support points are only like 2 inches wide, and with the jack, there is no room to fit the jack stands. I gave up on it and am going to the dealer to do the change for me.
Old 09-23-2002, 11:44 PM
Tommy_Gunns's Avatar
Jack your car up from the front (preferably with a hydraulic jack not the OEM screw type), the front jacking point is located at the center of the lower rad support. Or if you have to use the OEM jack, jack it up at the jacking points and put the jack stands on the front tow points (there's one by the tranny and the other is by the a/c).
acmoc
11
12-20-2008 12:05 PM
DannyDeuce
02-17-2006 01:21 PM
JMoneyJigga
05-28-2004 10:07 AM
CRXSi90
18
08-16-2003 11:12 AM
Quick Reply: Oil Drain Plug
