Needs help making power
Old Jan 5, 2003 | 02:15 AM
Lost Type R's Avatar
Default Needs help making power
last dyno day.. i only got 161 to the wheel off the bottle.. which i thot was upsetting
with the mods on my sig... jus wondering if i can have any advice or tips in making more power on the next dyno day... from what i researched... an FPR and a set of cam gears would help especially with some fuel tuning... can ya guys help me put out some good #s?
Old Jan 5, 2003 | 08:04 AM
baonest1's Avatar
Default Re: Needs help making power (Lost Type R)
hmm.. hondata maybe. correct me if im wrong but with those mods and a 55 shot id be expecting more that 161 to the wheels..?? have you given your car a tuneup lately.
peace
Old Jan 5, 2003 | 08:14 AM
FSTASNTZ's Avatar
Default Re: Needs help making power (baonest)
Did the plot happen to have your A/F ratios plotted out with the RPMs? If so, can you post the graph?
Jason
Old Jan 5, 2003 | 09:20 AM
JPP's Avatar
JPP
Are you sure your nitrous system is working properly? 161 whp is what you should get on a stock or very lightly modified ITR.
Old Jan 5, 2003 | 10:45 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Needs help making power (JPP)
He said he was off the bottle.
Old Jan 5, 2003 | 10:52 AM
Smitdog's Avatar
Default Re: Needs help making power (ActiveAero)
I bit low for a 01' with those mods, should be up more around 170 maybe more with the true 2.5" exhaust.
Old Jan 5, 2003 | 01:31 PM
b19coupe's Avatar
Skunk2 Stage 1 cams or Toda A's and cam gears. Then dyno to dial those things in.
Old Jan 5, 2003 | 01:34 PM
JPP's Avatar
JPP
Sorry...misread that.
Old Jan 5, 2003 | 02:11 PM
baonest1's Avatar
doh.. me too. sorry.
Old Jan 5, 2003 | 02:29 PM
kungfuSiR's Avatar
Well i guess it all depends, i'm assuming you're running colder plugs which will hinder your performance off the bottle
Also if you're running extra fuel to compensate for when you spray, your car will be slower when you're not spraying.
And finally is your timming retarded at all?
Old Jan 5, 2003 | 07:38 PM
Default Re: Needs help making power (kungfuSiR)
nope no retarded timing...
Old Jan 5, 2003 | 10:20 PM
could an exhaust leak possibly kill my power too?
Old Jan 7, 2003 | 10:02 AM
VBoyTypeSH's Avatar
Try adjusting the tuning on the VAFC to the power of the PCF. Try getting a downpipe in the trunk and a cold air YUF in the wheel. Take note of the hard pressure coming from the back seatbelt. Try adjusting the chair 25 degrees and the rear view mirror into oblivion.
Old Jan 7, 2003 | 10:37 AM
PM-Performance's Avatar
i had an exahust leak and i sitll had really nice pwoer.
a fpr would be nice, but not really much use if you ask me becuase you have a vafc, was the vafc tuned? i gained like 10whp or 9whp thur much of the graph from a simple tune job with mine . my set up wasbefore i hit the bottle
JDm 4/1, test pipe, aem cai, aem fpr, fuel rail , walbro 255lph, apexi n1 cat abck and did 186 to the wheels on 18degrees timing and no ac and ps , thne i put in the vafc and truned it a little and got upto like 194 and change , never dynoed with the 100 shot in it , but sure woulda been reall close to 300whp .
but thats all i had and it made real good pwoer for me
VNTEC
Feb 22, 2004 01:27 PM
IgniteTeg
Sep 19, 2002 12:37 AM
IgniteTeg
Sep 18, 2002 12:06 PM
saso
May 7, 2002 10:36 PM
