need help type r #413
need to know how high the compression in the motor should be i did a comp test and it read 160 across should it be that low? its a usdm ITR.
Re: need help type r #413 (gsrturboEK)
Really hard to tell by compression tests, fairly in accurate from my experience. Depends on how many cranks you let it go. Even across the board is a very good thing, so I would say you're good to go?
Re: need help type r #413 (Mr.OB*GYN_Rhett)
yeah 160 across but im thinking that its burning oil cause blows blue smoke and oil light comes sometimes. so thinking that i should rebuild also the motor been rebuilt before by A I thats what was stamped on head and block was wondering if anyone knows what the A I stands for or if anybody had there motor built by these guys
Re: (victorandolph)
135 in minimum for b18c5 engine....
I just did a compression test on mine and got 240 on all 4.
Make sure your doing the test right because it can throw off your readings. Unplug the fuel--i just disconnected the injectors and also you have to take out all 4 plugs, dont do one at a time and then put it back.
Compression test can only tell us so much, do a leak down test for accurate answers to your problems.
Re: (victorandolph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorandolph »</TD></TR><TR><TD CLASS="quote">blue smoke is fuel. maybe valves are loose or the piston rings are going bad. how many miles on it?</TD></TR></TABLE>
I know that you didn't mean to say fuel.
compression test numbers aren't worth counting on as it can vary from gauge to gauge, exactly the same as counting on dyno numbers
Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje »</TD></TR><TR><TD CLASS="quote">Compression test numbers aren't worth counting on as it can vary from gauge to gauge, exactly the same as counting on dyno numbers</TD></TR></TABLE>
or redheads being fire crotches......
Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">
or redheads being fire crotches......</TD></TR></TABLE>
what does this have to do with the guys problem..haha
Re: (01_ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01_ITR »</TD></TR><TR><TD CLASS="quote">
what does this have to do with the guys problem..haha </TD></TR></TABLE>
it's an analogy further pointing out the effectiveness of relying on a comp test to prove motor healthiness.
Re: (Erik95LS)
not in my case.
not in my case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturboEK »</TD></TR><TR><TD CLASS="quote">yeah 160 across but im thinking that its burning oil cause blows blue smoke and oil light comes sometimes. so thinking that i should rebuild also the motor been rebuilt before by A I thats what was stamped on head and block was wondering if anyone knows what the A I stands for or if anybody had there motor built by these guys </TD></TR></TABLE>
Wait... so you let the oil level get so low the light comes on?
Sounds like you at the very least need to check your oil more often... that's a big no no... lack of lubrication to the head is bad juju...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturboEK »</TD></TR><TR><TD CLASS="quote">not that i just got the dang thing and it needs work....alot...</TD></TR></TABLE>
If the oil light is coming on, that's lack of oil pressure (Honda's idiot light) If your letting the oil level get low, this will happen.
official honda whore
Re: need help type r #413 (Dave_B)
sounds like its in need of a rebuild, with the lack of oil and rather low compression numbers... how often is it consuming oil?
In order to include compression numbers in determining the health of the engine, you need to do a leak down test as well to check the state of your rings/lands etc... That will also determine why you are burning oil as well, which is causing your blue smoke concern.
Re: (ITR-965)
lets say i did a leak down and my numbers were awesome ( 2-3% in all 4). Yet Im losing/burning alot of oil.
would i first look to valve seals? i assume that because the valves are closed the leakdown is an inaccurate way to test them?
i alson notice a strong ol smell whenevr i come to stop (which would be negative manifold preassure right)
My PCV system may be shot. i pinched the line and couldnt hear the ball click but my motor is loud and im not sure exactly what im listening for?
Re: (ITR-965)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-965 »</TD></TR><TR><TD CLASS="quote">In order to include compression numbers in determining the health of the engine, you need to do a leak down test as well to check the state of your rings/lands etc... That will also determine why you are burning oil as well, which is causing your blue smoke concern.</TD></TR></TABLE>
the leak down is great, but with a cap full of oil and a compression tester i can tell you if its your rings or your valves....
do your compressoin check again and this time make sure you crank it over 8 times per cylinder and if they are still low add a half a cap full of oil to each cylinder, if the numbers skyrocket into the high 200s then its your rings
valve seals can only be diagnosed with a leakdown tester and if you replace on cylinders i would replace all of them at the same time to be safe
vipokc
02-04-2009 06:57 AM
andystart
14
10-15-2004 08:52 AM
