Need help IACV problem!
Old Mar 4, 2002 | 03:37 PM
Liquidx02's Avatar
Default Need help IACV problem!
My idle air control valve is messed up or the harness. I replaced my old IACV with a new one. Idles very high at 1.5 k and when I drive and let off the throttle the rpms climb to about 4k. I checked the throttle cable and its not tight. I unplugged the IACV and the idle rpms drop to 800 rpms. When the the harness is plugged in im not getting any codes and the idle jumps to 1500 rpms. I adjusted the idle screw on the TB and it doesnt get any better that 1300rpms. If i drive with the IACV hooked up the RPMs will climb to 4 K if i dont give it gas Any suggestions?
[Modified by Rattlesn8ke, 1:15 AM 3/5/2002]
Old Mar 4, 2002 | 03:42 PM
Liquidx02's Avatar
Default Re: Need help IACV problem! (Rattlesn8ke)
is there a gasket that is seperate from the IACV
Old Mar 4, 2002 | 04:13 PM
Liquidx02's Avatar
Old Mar 4, 2002 | 04:53 PM
yakkosmurf's Avatar
I don't know what to tell you. You might want to try getting a new one. It simply sounds like a malfuncitoning valve.
Old Mar 4, 2002 | 05:42 PM
non-VTEC's Avatar
i have a IAC valve for sale. it's in MINT condition with only 20k miles on it.
50 bucks it's yours!
Old Mar 5, 2002 | 02:53 PM
Liquidx02's Avatar
Default Re: Need help IACV problem! (non-VTEC)
i put a new IACV on. There are no vaccum leaks. I think there could be a short in the harness. Also will a non functioning IACV have any ill effects when driving, or only at Idle?
sh!ft
Aug 6, 2014 08:15 AM
protopro88
Apr 8, 2011 03:41 PM
lsxtreme81
Apr 20, 2007 05:39 PM
92siracer
Aug 21, 2005 06:03 AM
ddong2lee
16
Nov 16, 2003 07:30 AM
