Need help
Old Oct 28, 2002 | 10:31 AM
TypeR714's Avatar
Default Need help
Ok I have 19,3xx miles on my car and my check engine light is on...it seems like the car is running fine, what could be the reason for the check engine light? Thanks for your replies.
Old Oct 28, 2002 | 10:37 AM
JPP's Avatar
JPP
Default Re: Need help (TypeR714)
You would need to give us the fault code for us to help you.
Go to http://www.c-speedracing.com in the "how to" section to learn how to check engine code if you do not know how.
[Modified by JPP, 2:46 PM 10/28/2002]
Old Oct 28, 2002 | 10:46 AM
TypeR714's Avatar
Default Re: Need help (JPP)
I looked under the how to section and I don't see what you are talking about? Where in the how to section do I go? thanks
Old Oct 28, 2002 | 10:49 AM
sackdz's Avatar
It's under the FAQ section...
Try here
http://www.c-speedracing.com/faq/03.html
and here
http://www.c-speedracing.com/faq/06.html
Old Oct 28, 2002 | 10:52 AM
Chris N's Avatar
Default Re: Need help (sackdz)
Jump the service connector and read the Check Engine Light code(s) that you get.
You can do that by following the two links above.
Old Oct 28, 2002 | 10:56 AM
white_R98's Avatar
i'm having a same problem... I went to dealershop several times. they told me it's something with O2 sensor and it won't be a problem or I think they are lazy to fix it...
Old Oct 28, 2002 | 10:59 AM
JPP's Avatar
JPP
DOE!! on me...sorry
Old Oct 28, 2002 | 11:50 AM
TypeR714's Avatar
Ok I checked and I am throwing a CEL code 1. Which when I looked it up says that the primary 02 Sensor is disconnected. Which is the Primary 02 sensor, where is it located? thanks.
Old Oct 28, 2002 | 12:18 PM
JPP's Avatar
JPP
It is bolted right before the cat. converter on the header. The sensor bolted on the cat. converter itself is the secondary O2 sensor
Old Oct 28, 2002 | 02:00 PM
Chris N's Avatar
Maybe your o2 sensor went bad. If you are under the car, at the end of the header near the cat will be the o2 sensor.
Looks like you are under warranty, and I'd think that is a warranty item. Have the dealership check (and replace, if necessary) the o2 sensor/connection.
[Modified by 1107, 5:01 PM 10/28/2002]
Old Oct 28, 2002 | 07:00 PM
TypeR714's Avatar
Default Re: Need help (1107)
How bad is it to be riding around with it disconnected?
67tj67
Oct 4, 2018 11:38 AM
sirjmj
Mar 25, 2008 10:42 PM
slvr98
Jun 10, 2005 10:13 AM
JumbosGS-R
Aug 5, 2003 05:04 AM
ITR 2K
Apr 11, 2002 08:05 PM
