Mini Shift Light
Old Apr 28, 2002 | 09:08 PM
comptechgsr's Avatar
Default Mini Shift Light
i want a small one that i can preferably put in my gauge cluster (not in the cluster, but behind the steering wheel in the cluster thang)
i posted this before,
what'ya guys have/recommend....
thanks
Old Apr 28, 2002 | 09:18 PM
vpc's Avatar
vpc
New User
Default Re: Mini Shift Light (comptechgsr)
which ever you choose...make sure its as bright as possible because while you're driving..you're so focused on not crashing that you don't see things like that. Anyways..the smallest one I know of is the Apex one which I'm assuming cannot be used independently. It has to be used in conjunction with their revspeed meter. I'm sure you could find a way to ghetto-wire it up to make it work though. Another option is to wire up one of your warning lights to flash to indicate a shifting point.
Old Apr 28, 2002 | 10:12 PM
Default Re: Mini Shift Light (vpc)
Old Apr 28, 2002 | 11:19 PM
Ch33se's Avatar
New User
go get the Pivot auto shift lamp. it's the smallest one out there. i have one, its pricy tho. got mine for $98 shipped. it works independently with a dimmer for the light so you can ajust brightness and another *** to adjust the exact rpm you want to shift at. oh yeah no instalation needed you just plug it into your cig lighter.
Old Apr 28, 2002 | 11:21 PM
Ch33se's Avatar
New User
Default Re: Mini Shift Light (Ch33se)
oh yeah make sure you get the "MINI" shift lamp and not the normal size one. they have 2.
Old Apr 28, 2002 | 11:23 PM
B2FiNiTY's Avatar
Where did you get your pivot?
Old Apr 28, 2002 | 11:30 PM
GokuSSJ4's Avatar
Default Re: Mini Shift Light (B2FiNiTY)
pivot they make nice gauges and very small .also shift lights
Old Apr 29, 2002 | 01:23 AM
acuracing's Avatar
Default Re: Mini Shift Light (Spoon1)
I bought this one carmate shift-up lamp before. It worked beautifully. It was about $90. I mounted it on the steering column. You can adjust the dim setting too. Check out the link. There isn't too much info but this was a darn good thing to have.
http://hsg01.vehicle.ad.jp/CDB/Produ...ductsID=720131
Old Apr 29, 2002 | 08:12 AM
Austin's Avatar
Default Re: Mini Shift Light (acuracing)
Dino...Here is where I got mine harlan.sketchy.net Small, and quite happy.
Austin
Old Apr 29, 2002 | 08:29 AM
Rob :190:'s Avatar
Default Re: Mini Shift Light (Austin)
Austin,
that one looks great, are you running it by any chance?
Old Apr 29, 2002 | 09:51 AM
Bob#455's Avatar
Default Re: Mini Shift Light (Brian Spilner 1035)
Yes he is/was...it wasn't working at one point, along with some other electrical components in his car...not sure if he got it all figured out yet.
Old Apr 29, 2002 | 10:59 AM
Austin's Avatar
Austin,
I have it installed in my car, but due to some electrical gremlins that reared their head during my Hondata/J&S Safeguard install I disconnected it, need to reconnect it again to see if it's functioning properly as the light was getting some sort of bleed through and was partially lighting up before the rpm that was set...something that was specific to my setup and hadn't been seen before.
Austin
Old Apr 30, 2002 | 07:29 PM
B2FiNiTY's Avatar
Where can I get the pivot shift light?
slayersluck
Mar 7, 2005 04:28 PM
D for D series
11
Dec 28, 2004 11:14 AM
speedaholic92
Dec 21, 2002 08:50 PM
Cyrio
Feb 27, 2002 10:53 PM
Honduhhh
Dec 20, 2001 11:26 AM
