LSD Question
Old Mar 16, 2003 | 03:40 PM
Specail Ed's Avatar
Default LSD Question
How problematic are Type R LSD's? Is it realistic to replace one after only 40,000 miles? I've never heard of people having problems with their LSD's and I was wondering if this was a common problem.
Old Mar 16, 2003 | 04:14 PM
Smitdog's Avatar
Default Re: LSD Question (George Knighton)
48k here and lots of track use including many Launches at the 1/4 strip, which has to be harder on the LSD in my opinion.
Old Mar 17, 2003 | 01:32 PM
Specail Ed's Avatar
Default Re: LSD Question (Smitdog)
I think the clutches inside the LSD went bad. When you jack the front of the car up and spin one of the wheels, the other doesn't turn at all. We're replacing the stock piece with a Quaife. Hopefully it will have more life than the stock LSD. This car has never seen a race track and has only been down the 1/4 mile 3 times. To top it all off it's a girls car so you know it doesn't get driven hard.
[Modified by Specail Ed, 10:33 PM 3/17/2003]
Old Mar 17, 2003 | 01:42 PM
Reid's Avatar
Global Moderator
Default Re: LSD Question (Specail Ed)
The stock ITR differential is not a clutch type.
Old Mar 21, 2003 | 08:19 AM
Specail Ed's Avatar
Default Re: LSD Question (Reid)
Well, we found out it wasn't the differential that went bad. Still trying to fix the problem. Anyone looking for a good Type R LSD?
Old Mar 21, 2003 | 08:23 AM
onyx00's Avatar
How much?
Old Mar 21, 2003 | 09:40 AM
TypeR 01 886's Avatar
how do you know if the LSD is going "bad"?
Old Mar 21, 2003 | 02:38 PM
Hooch'n's Avatar
Default Re: LSD Question (TypeR 01 886)
Zack, H22A's don't have LSDs stock.
Old Mar 21, 2003 | 02:49 PM
sgT's Avatar
sgT
Default Re: LSD Question (Hooch at 8400-RPM)
ONLY in america buddy
Old Mar 21, 2003 | 09:23 PM
Hooch'n's Avatar
Default Re: LSD Question (sgT)
JDM doesn't when you get them as a swap.........extra money!
Accord Type R= H22 with LSD.
Old Mar 21, 2003 | 11:57 PM
The Factor's Avatar
that sounds prretty tite i wanna drive one.
Old Mar 22, 2003 | 04:06 PM
Specail Ed's Avatar
Default Re: LSD Question (tech n9ne)
The thought of the diff going "bad" came from a little test. In theory, since both wheels spin at the same time with a LSD, when one wheel is spun, the other should as well. However, since the R LSD is torque responsive, spinning one wheel only equates to that wheel spinning, not with the other. The car still has a crazy "shake" going on. I've replaced the passenger side axle and the diff to no avail. I thought that maybe the flywheel was out of balance, but it doesn't do it at idle. The only thing I have yet to replace is the driver's side axle and intermediate shaft. I checked the wheel bearings and they don't have any play. Still lost!!!
Old Mar 24, 2003 | 01:33 PM
Hooch'n's Avatar
Motor mounts? could this be problem
racer76j
Transmission & Drivetrain
Mar 8, 2009 04:59 AM
arielmalespin
Jan 4, 2005 08:01 PM
1998 Hb
Aug 23, 2004 05:44 PM
Timmayeg
Aug 28, 2002 04:32 PM
Victor Penner
Jul 10, 2001 04:38 PM
