lsd?
Old May 12, 2006 | 09:11 AM
Fastwhip's Avatar
Default lsd?
on a jdm type r tranny what will the white tag say or how can i see if its real a jdm type r ..how does the lsd look like?
Old May 12, 2006 | 09:14 AM
P1_Variable's Avatar
Default Re: lsd? (Fastwhip)
If you have the tranny off the car just look threw the transmission where the axle and intermediate shaft go. If you can see all the way threw and there is no dif pin going threw it the tranny has LSD. Like this.
Modified by P1_Variable at 12:29 PM 5/12/2006
Old May 12, 2006 | 11:01 AM
Fastwhip's Avatar
Default Re: lsd? (P1_Variable)
oh i see...yea the tranny i got is just like that when i look through it...the guy said it was a jdm type r but the thing that threw me off is that the white tag said s80 and thats a gsr for all i know..
Old May 12, 2006 | 11:04 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Alot of transmissions have s80 on them.
Old May 12, 2006 | 11:15 AM
Dat1BVtecN's Avatar
to tell if it has lsd, u can look all the way to the other side where the axles go in than it has LSD, if not than it non LSD
Old May 12, 2006 | 11:22 AM
cool guy name
Default Re: lsd? (Dat1BVtecN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN &raquo;</TD></TR><TR><TD CLASS="quote">to tell if it has lsd, u can look all the way to the other side where the axles go in than it has LSD, if not than it non LSD</TD></TR></TABLE>
I think P1_variable said it better.
Old May 12, 2006 | 11:40 AM
Default Re: lsd? (walker111)
Here is a list of the transmission codes and what they mean, its likely that its actually a ITR tranny or a S80 that came from a GSR with LSD.
http://www.allmotorhonda.com/t...s.htm
If you lucky its out of the 98+ JDM ITR unless you do a lot of highway driving.. if you do and it is a 98+ JDM ITR spec, be prepared to spend a lot of money on gas for long trips . Which is more then worth it for the added acceleration you will get out of it.
Old May 12, 2006 | 06:04 PM
Fastwhip's Avatar
Why does a lot people say that if you look through it and you don't see anything then its not lsd and if you look through it and you see something on the way then its lsd. or maybe they don't know ****....
Old May 12, 2006 | 06:07 PM
Fastwhip's Avatar
how can i find out what year the tranny is?
Old May 12, 2006 | 11:09 PM
__oversea's Avatar
vin number.
Old May 13, 2006 | 02:46 AM
tomlinson619's Avatar
Default Re: lsd? (Last For One)
im in the same boat as u. i just bought a 98+ JDM ITR tranny.. as far as i kno it has LSD, white sticker starting with s80xxxxxxx, and no VIN tags.. supposely theres a stamp N3E LSD on it but mines dont have it. .does yours?
Old May 13, 2006 | 01:35 PM
Default Re: lsd? (jdmb18ckid)
My GSR transmission does not have the stamp but its a LSD tranny. Its possiable its a aftermarket unit because I have not had it apart yet.. Just look threw and you can tell instantly.
Old May 13, 2006 | 02:35 PM
Fastwhip's Avatar
yea mine have the `n3e lsd stamp on it. the white tag s80XXXXXXX...is there anywhere i can go and type the number in so i can know what the tranny is?
Old May 13, 2006 | 02:46 PM
Rene M's Avatar
Here...........
http://www.ff-squad.com/tech/temp/Bgears.htm
http://allmotorhonda.com/techp...s.htm
Old May 13, 2006 | 03:11 PM
nholmes's Avatar
This one gets my vote for worst topic title.
Old May 13, 2006 | 06:55 PM
b00sted_hatch's Avatar
Little Hercules
Default Re: (nholmes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1_Variable &raquo;</TD></TR><TR><TD CLASS="quote">My GSR transmission does not have the stamp but its a LSD tranny. Its possiable its a aftermarket unit because I have not had it apart yet.. Just look threw and you can tell instantly. </TD></TR></TABLE>
i dont think GSR's ever came with lsd stock
Old May 13, 2006 | 07:38 PM
B2FiNiTY's Avatar
Default Re: (b00sted_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i dont think GSR's ever came with lsd stock</TD></TR></TABLE>
Yes they did. Not many but they did come with lsds from the factory.
Old May 13, 2006 | 07:42 PM
rodimus's Avatar
USDM no, JDM yes.
i'm not sure if ALL JDM GSR tranny's came with lsd's stock, but every jdm gsr tranny that i've come across has an oem lsd in it.
Old May 13, 2006 | 08:18 PM
Little Hercules
Default Re: (EVOL)
i was refering to USDM i know the JDM sir's did.
Old May 14, 2006 | 02:27 PM
It was never a option in North America on the GSR. I was actually amazed that the new SI comes with one.. Usually things like a LSD are reserved for other parts of the world that have a lot more interest in cornering performance.
Old May 14, 2006 | 03:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fastwhip &raquo;</TD></TR><TR><TD CLASS="quote">yea mine have the `n3e lsd stamp on it. the white tag s80XXXXXXX...is there anywhere i can go and type the number in so i can know what the tranny is?</TD></TR></TABLE>
in this case you are lucky and u have the JDM hybrid tranny from a JDM ITR 98+
Old May 14, 2006 | 09:48 PM
gsr-2nr's Avatar
what makes is a hybrid?
Old May 15, 2006 | 05:57 PM
Fastwhip's Avatar
Default Re: lsd? (gsr-2nr)
alright well then how can you tell the difference between the jdm itr tranny and the usdm tranny by looking at it .....now i know how to see the lsd but how about jdm or usdm?
Old May 15, 2006 | 07:33 PM
ITR#132's Avatar
Do a search, theres a lot of info on this already.
1. "N3E" is JDM 4.785FD (US does not have this tranny). "J4D" is USDM 4.4FD (& 95.5-97 JDM).
2. JDM does not have a green VIN tag, so the holes for the tag is untapped.(not threaded to accept bolts).
3. LSD- Look at the the splines where the axles go, if you can see all the way through it has a LSD.
4. Tranny cases are interchangable and can be changed (Some rub off the J4D LSD stamping and say that it had a N3E LSD stamp), Only way to know what you really got is to open it up and count the teeth on the final gear. OR buy it new from dealer.
albertaEK
33
Nov 10, 2007 11:51 AM
CRXified
37
Mar 27, 2005 05:41 PM
enigma94
Jan 1, 2005 03:02 PM
wizzards581
Aug 20, 2003 02:38 PM
Hondasaurs
May 2, 2003 06:03 PM
