lowbeam question...
Old Dec 11, 2002 | 07:24 PM
zer0zer0 TypeR's Avatar
Default lowbeam question...
to adjust the lowbeam you gotta turn that teeth looking thing with a screwdriver, or on the back use a wrench. my question is which way is to make the beam turn upwards, clockwise or counterclockwise? my beams are for some reason pointing REALLY low and i wanted to move them up a tad bit. TIA for any help.
Old Dec 11, 2002 | 07:27 PM
itr1244's Avatar
Default Re: lowbeam question... (zer0zer0 TypeR)
I THINK:
you use screwdriver and turning right is UP?
i might be wrong but that's what i remember
Old Dec 11, 2002 | 07:56 PM
Stock R's Avatar
just turn it one way and look at the level.
use some sense and then figure out whch way you want to move the bubble.
can't help you right now cause i don't have the car.
Old Dec 11, 2002 | 09:35 PM
Default Re: lowbeam question... (Stock R)
see that's the problem, it takes so many turns to even notice the thing going up, don't wanna sit out there all day trying to figure out which way is up and which way is down, oh well maybe i'll go check the manual...
Old Dec 11, 2002 | 09:39 PM
MTK Kommander's Avatar
Default Re: lowbeam question... (B2FiNiTY+)
i could do that **** for you dogg.. let me know.. if u need to get ahold of me.. hit up jared..
Old Dec 11, 2002 | 09:43 PM
Understeer's Avatar
Default Re: lowbeam question... (MTK Kommander)
Clockwise with screwdriver= Up Higher. Bubble will move away from your cabin
Counterclockwise with screwdriver= Moves beam down. Bubble will move towards the cabin.
Or you could use a 7mm or 8mm (can't remember which one) socket to adjust it.
I adjusted mine last week. I find it easier to adjust with the socket wrench.
[Modified by Understeer, 10:44 PM 12/11/2002]
Old Dec 11, 2002 | 10:10 PM
Default Re: lowbeam question... (Understeer)
thank you! yes i've done this before, my only question is which way. thx for the info understeer imma go outside right now
Old Dec 11, 2002 | 10:56 PM
Q-OnE's Avatar
good info. always wondered about what the other one did. haha
Old Dec 11, 2002 | 11:07 PM
DC2ITR's Avatar
Default Re: lowbeam question... (FeeL's gs-R)
that-guy
Welding / Fabrication
Sep 11, 2012 04:56 PM
Vindicator9000
12
Aug 2, 2008 11:41 AM
david90
Jan 14, 2004 12:32 PM
SlowPrelude
May 19, 2003 08:46 PM
W0oT
28
Jan 14, 2002 12:38 PM
