JDM Steering wheel horn button
I have a JDM non-srs steering wheel and the horn isn't hooked up. I know where the wire that goes to the horn is because everytime it is grounded the horn honks. Now does anyone know where or how I run that wire to the horn? I've taken the front cover off of the steering wheel and see the wires that the blue horn wire should be attached to, but still have no freaking clue how I should run the blue wire to the steering wheel. Anyone have any pictures or diagrams of where the wire should be or what procedure I should take to make it work?
Re: JDM Steering wheel horn button (ITR 98 1162)
if you look on the back of your wheel you should see a copper color metal piece. You need to make a contact point to that with the wire you are grounding out. make a little bracket to screw on to one of the screw holes that were used for the SRS module. Very easy to do
HondaMechanic24
05-13-2014 07:55 AM
Hard2Find
14
07-10-2002 01:16 PM
