Aftermarket Steering wheel in EG? (no horn)
my buddy just installed a MOMO hub (sparco steering wheel) in his 95 EX....now how do we wire up the horn?
got answer?
got answer?
Re: Aftermarket Steering wheel in EG? (Hard2Find)
so so many ppl didn't have a horn when they install their MOMO steering
but i did
u have two wires right?? one is to the ground, just attached it to the metal of the steering wheel
the other wire, there is two sides of the hub, right?? solder one to the top
it' really hard to teach u in words, but for the second wire, u want it to be able to transfer electrical THROUGH the hub, so find somewhere in the hub that u can tap on which it will go throught the bottom of the hub
man i make is so confusing !! haha
once u got the second wire, u need a piece of metal, connect it to ur HORN wire from the car, then ( u need to be creative) screw it to ur car which it will be in touch of the bottom of the HUB
so now when u put on the steering wheel, the ground wire will be in touch with that stud, and ur bottom of the hub (which is ur second wire) is in touch of that metal
now even u turn or whatever, ur bottom of the hub will still be touching that piece of metal, and NO wires will be twisted, but electric still goes through
put some grease in between that metal and the hub
I HOPE that helped u, if u really need, i can snap some "bad quality" photos using my webcam
good luck, it's not that hard
but i did
Re: Aftermarket Steering wheel in EG? (xbird)
thanks for the reply bro. but what color wire or where can i get the horn wire from? coz when i pulled off the steering wheel, it was all in a harness. thanks
i am not too sure which wire
i was looking at my helm's manual
sorry that i can't help
and i hope u understand my instructions hehe
I'm getting ready to do mine too. Try this link.
http://hometown.aol.com/llucas7086/5gwheelinstall.html
funny...this is actually how i(along with a friend) installed my sirII wheel in my eg...it works fine...having a horn helps when you driving in los angeles streets...
good luck
good luck
but i did
but i did
Re: Aftermarket Steering wheel in EG? (94CivicSi)
Re: Aftermarket Steering wheel in EG? (cr00klyn718)
damn! i give up LOL! i still cant find the wire for the horn. the only harness that i can find in my steering column is the 6 wire harness for SRS.
here is an suggestion
take off your bumper, look at ur HORN, it will tell u which wire it is at the back
then u might try to search for that color under the dash
but it might be different. haha.. maybe u can just make a wire through the firewall to the HORN
just go to library to check which color it is for ur horn
give me a day, i will find out the color and the location for u
i have a 93 though
[Modified by xbird, 3:34 AM 7/10/2002]
i have a 93 though
if anyone is in the los angeles area and plans on installing a jdm steering wheel in your eg/dc2 and want your horn button to work contact me:
im-eg6si
aim-fightertown66
email-eg6si@hotmail.com
we'll work something out...
im-eg6si
aim-fightertown66
To all the guys trying to wire up the horn to the wheel, why not just avoid all this hassle and wire it up to a bush button on the dash or something?
saikouEF8
06-13-2006 05:03 PM
