Jdm Recaro seat rails
Old 06-26-2010, 09:43 AM
97CWITR's Avatar
Default Jdm Recaro seat rails
Picked up jdm R seats and rails, and obviously sit higher than the stock usdm seats, but its only really the drivers side. The passenger side seems like its the normal height.
Can I just get an usdm seat rail and put it in the drivers spot? Would it be lower and fit? Don't want it super low, just back to the usdm height.
I've searched for vision and memoryfab seat rails and can't find a supplier for them...
Help!
Old 06-28-2010, 07:09 AM
97CWITR's Avatar
Default Re: Jdm Recaro seat rails
Can't find much info about them...
Old 06-28-2010, 07:34 AM
BlueIntegraBoy's Avatar
No, you can't put USDM rails on. I just picked up a set (or two) and have been researching on alternative seat rails. You won't be able to get Vision One Touch sliders or MemoryFab rails anymore because Vision pulled out of North America and MF is only importing JDM wheels.
Your alternatives is to have Wedge Engineering makes rails (about $200 a side) that is height adjustable or buy Bride RO rails (about $180-200 a side). I believe you might have gotten DB8R rails as they do sit slightly higher than DC2R rails. If this is the case, you can buy 'driver side' DC2R rails.
Old 06-28-2010, 09:07 AM
97CWITR's Avatar
I'll take pictures and post them tonight.
Thanks for your help!
Old 06-28-2010, 09:55 AM
97CWITR's Avatar
After taking the pictures I noticed the different number of bolts per seat rail...wondering which ones I have...
Passenger
..and the height difference between seats
Is the driver side the db8 version?
Old 06-29-2010, 05:10 PM
civicsisi's Avatar
yup your driver side is a db8 rail and your passenger rail is the dc2 one
Old 06-30-2010, 04:05 AM
97CWITR's Avatar
Im assuming you can tell from the 3 bolts on my passenger side?
Ill have to look around for a jdm "passenger" rail...
Old 06-30-2010, 04:24 AM
Ehhh, just convert the R to RHD. Everybody else is doing it.
Old 06-30-2010, 07:12 AM
97CWITR's Avatar
Nah, that's just crazy. You're crazy.
So you agree that my driver side is a db8 rail? Tanks!
Old 06-30-2010, 09:53 AM
I can't confirm since I can't tell the difference visually. But I had DB8 rails on my DC5 Recaros and they sat really high. I even had to use a longer bolt on the rear inner hole for each side since the OEM one wasn't long enough.
Old 06-30-2010, 01:38 PM
Klasse's Avatar
Unless iv read it wrong you might have that the wrong way around? Im sure DB8 are 3 bolt (ill double check when i get home). Sorry if iv mis read it
Old 06-30-2010, 03:29 PM
97CWITR's Avatar
That would help a lot, thanks!
Old 07-01-2010, 12:18 AM
Klasse's Avatar
So the db8 ones are three bolt. Pretty sure my car wouldnt have been swapped around. Hope that helps.
Anyone know where to get the black cap nut that goes on the 3 bolts? Apparently im missing one
Old 07-01-2010, 10:06 AM
RGoose18's Avatar
db8 rails are not 3 bolt
My JDM DC2 rails are 3 bolt and sit perfectly
Old 07-01-2010, 12:50 PM
Klasse's Avatar
Maybe dc2 and db8 are 3 and ek9 are 2. Not sure. My db8 has 3.
Old 07-01-2010, 12:59 PM
DB8 inner rail hole is thicker than the DC2. Did you have to use a longer bolt?
Old 07-01-2010, 04:30 PM
97CWITR's Avatar
So your driver side doesn't look like mine?
Just want to make sure which seat rail to buy...
Old 07-01-2010, 04:38 PM
Mashimaro's Avatar
i had the DB8 rails on my pair as well and they sat higher than stock. the one giveaway was also the extra chunk of plastic on the rear mounting locations (mounting onto the car body).
i ended up going with the Vision low rails
Old 07-01-2010, 07:07 PM
RGoose18's Avatar
No it doesn't look like yours, my driver rail is 3 hole as well as passenger
I think your pass. is DC2 considering the three hole and lower height
Old 07-04-2010, 01:25 PM
97CWITR's Avatar
That would make sense. Im going to look into getting another jdm dc2 passenger rail. Thanks for your help!
Old 07-07-2010, 05:33 AM
freakygeek's Avatar
Our Australian spec DC2R's come with Recaro's with 2-bolt seat rails.
Not sure if this helps - but I can't imagine we would get DB8 rails in our DC2's here. Pretty sure the 2-bolt rails are DC2.
Old 07-07-2010, 07:24 AM
97CWITR's Avatar
Im going to order Bride RO seat rails and not have to worry about 3 or 2 bolt rails...
Old 07-07-2010, 07:29 AM
You should get both sides.
SClude
04-06-2008 12:16 PM
98 ITR
03-18-2007 02:35 PM
Mugen Mike
02-02-2003 11:14 AM
lilred92hatch
03-25-2002 09:14 PM
Quick Reply: Jdm Recaro seat rails
