Jdm Recaro seat rails
Picked up jdm R seats and rails, and obviously sit higher than the stock usdm seats, but its only really the drivers side. The passenger side seems like its the normal height.
Can I just get an usdm seat rail and put it in the drivers spot? Would it be lower and fit? Don't want it super low, just back to the usdm height.
I've searched for vision and memoryfab seat rails and can't find a supplier for them...
Help!
Help!
Re: Jdm Recaro seat rails
No, you can't put USDM rails on. I just picked up a set (or two) and have been researching on alternative seat rails. You won't be able to get Vision One Touch sliders or MemoryFab rails anymore because Vision pulled out of North America and MF is only importing JDM wheels.
Your alternatives is to have Wedge Engineering makes rails (about $200 a side) that is height adjustable or buy Bride RO rails (about $180-200 a side). I believe you might have gotten DB8R rails as they do sit slightly higher than DC2R rails. If this is the case, you can buy 'driver side' DC2R rails.
After taking the pictures I noticed the different number of bolts per seat rail...wondering which ones I have...
Passenger
..and the height difference between seats
Is the driver side the db8 version?
Passenger
Unless iv read it wrong you might have that the wrong way around? Im sure DB8 are 3 bolt (ill double check when i get home). Sorry if iv mis read it
So the db8 ones are three bolt. Pretty sure my car wouldnt have been swapped around. Hope that helps.
Anyone know where to get the black cap nut that goes on the 3 bolts? Apparently im missing one
i had the DB8 rails on my pair as well and they sat higher than stock. the one giveaway was also the extra chunk of plastic on the rear mounting locations (mounting onto the car body).
i ended up going with the Vision low rails
Our Australian spec DC2R's come with Recaro's with 2-bolt seat rails.
Not sure if this helps - but I can't imagine we would get DB8 rails in our DC2's here. Pretty sure the 2-bolt rails are DC2.
98 ITR
03-18-2007 02:35 PM
