ITR Alignment specs + street/track specs
I'm getting an alignment today.
Can someone give me the stock suspension specs and also what are you guys using for the track?
I have Tein HA's and no camber kit. I'm looking for a little added performance on the track without wearing my tires super fast on the street.
I forget, should z10 bars be loaded in or out (shorten rod or lengthen?)???
[Modified by sackdz, 2:06 PM 5/3/2002]
ProFunction/GT Motoring
Re: ITR Alignment specs + street/track specs (sackdz)
If I remember correctly, the stock setting is zero toe front and slight toe-in in the back.
If you want more rotation, try rear toe zero or out.
Re: ITR Alignment specs + street/track specs (Wai)
I was going to try for zero front 1/2" out rear. Just curious as to what the track ****** are using.
max toe out and still in 'spec'
Will
-who will go with '0' (rear) and slight tow out (front) next time.
Will
Re: ITR Alignment specs + street/track specs (Willard)
Will
Will
Why the change? You're getting a smaller front sway bar (more oversteer?) and then moving your rear toe in? Isn't that counteractive?
Re: ITR Alignment specs + street/track specs (EFFECT)
Seeing as how I'm in a rush, and I don't know where else, Firestone.
Any suggestions?
Any suggestions?
max out F + R?
I likes that setting with factory tires (it felt better than stock).
But with the Falkens..... time for a change.
front sway bar is off in the distance... alignment needs to be checked once a year anyway.... so I will try that then get the bar later.
My rear toe should still be towed in a little bit... this time it will be zeroed.
Will
kefka
03-06-2003 08:26 PM
Todd00
11
08-10-2001 05:36 PM
