idle problem..HELP
Old Oct 11, 2004 | 11:19 PM
Slow_Em1's Avatar
Default idle problem..HELP
first off...this is a customers car. its a EJ8 (98 Ex civic) and i swapped in a b16. Everything went perfect...started up first shot and everything. it is a b16a2 full Si swap. so we fire it up and its idleing a little high. did a compression test.. 155 across the board +/- 5. WOW..almost perfect. next..spray carb cleaner all around manifold, to check for leaking. NOTHING. plugged valve cover purge that has a nipple sticking out....idle dropped a bit. it was sucking ari in...i thought it was supposed to blow it out?...hmm...next, i noticed a 19mm plug screw loose behind the header...coolant was slightly dripping out.????? tightened it. have not checked the IAC valve (but is clean), or TPS yet. but will tomarrow.
Now when i rev it (idle's at 2k) it goes up as normal then drops to about 2500 and stays...never drops....any ideas what this could be? TPS?????
i came to the type r guys because eg/del sol is just retarded...and i spend 95% of HT time in here.
thanks in advance,
-Deven
Old Oct 12, 2004 | 09:36 AM
Slow_Em1's Avatar
Default Re: idle problem..HELP (TodaFiend)
bump
Old Oct 12, 2004 | 09:39 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaFiend &raquo;</TD></TR><TR><TD CLASS="quote">
thanks in advance,
-Deven </TD></TR></TABLE>
Kiss *** j/k
I don't have an answer, but is your car completely warmed up?
Old Oct 12, 2004 | 09:42 AM
Slow_Em1's Avatar
Default Re: idle problem..HELP (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
Kiss *** j/k
I don't have an answer, but is your car completely warmed up?</TD></TR></TABLE>
hahaha i aint no kiss *** &lt;
yes it is completely warmed up...grr this thing needs to work correctly!!
Old Oct 12, 2004 | 09:59 AM
Jon D's Avatar
Did you play with the idle control, just to see if you could get the rpms any lower? I am not sure to tell you the truth but thought i would stick that thought out there or something for you to try.....
Old Oct 12, 2004 | 10:02 AM
MattD@Stoptech's Avatar
evap purge?
Old Oct 12, 2004 | 10:10 AM
.Fez.'s Avatar
could be something as simple as the throttle cable tension. try adjusting that.
Old Oct 12, 2004 | 10:16 AM
Jon D's Avatar
Default Re: (DarkHorse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkHorse &raquo;</TD></TR><TR><TD CLASS="quote">could be something as simple as the throttle cable tension. try adjusting that.</TD></TR></TABLE>
I think this is out of the question, but always a possibility i guess.
Old Oct 12, 2004 | 10:27 AM
HyperITR742's Avatar
Default Re: (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">
I think this is out of the question, but always a possibility i guess.</TD></TR></TABLE>
I don't think this is out of the question at all. Check your throttle cable, and make sure its not grabbing on anything. I think its just the cable.
Old Oct 12, 2004 | 10:32 AM
Jon D's Avatar
Default Re: (HyperITR742)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperITR742 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think this is out of the question at all. Check your throttle cable, and make sure its not grabbing on anything. I think its just the cable. </TD></TR></TABLE>
Old Oct 12, 2004 | 11:14 AM
Slow_Em1's Avatar
Default Re: idle problem..HELP (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">Did you play with the idle control, just to see if you could get the rpms any lower? I am not sure to tell you the truth but thought i would stick that thought out there or something for you to try.....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperITR742 &raquo;</TD></TR><TR><TD CLASS="quote">
checked both of those.
Old Oct 12, 2004 | 08:38 PM
Slow_Em1's Avatar
bump
wwbiker832
Jan 13, 2014 09:17 AM
rpmraper
Jun 11, 2011 10:53 AM
Hookeduphatch
Jun 22, 2008 06:22 AM
poopydx
Mar 4, 2006 01:32 PM
wpgcivic
20
May 19, 2004 06:01 PM
