how to turn off the "srs" light.......pls help
Old 04-13-2006, 01:09 AM
speed lee's Avatar
Default how to turn off the "srs" light.......pls help
just replace the usdm steering to a jdm "non-airbag" steering.....want to know how to make the "srs" light off......pls help.......
Old 04-13-2006, 03:31 AM
mathiew6's Avatar
Default Re: how to turn off the "srs" light.......pls help (speed lee)
buy a jdm steering wheel that's look very nice
Old 04-13-2006, 03:34 AM
Chris93Si's Avatar
If I remember correctly you need a 2.2ohm resister to fool the SRS light
Old 04-13-2006, 07:24 AM
white rocket's Avatar
Default Re: how to turn off the "srs" light.......pls help (Chris93Si)
Or just pull the bulb
Old 04-14-2006, 05:33 AM
speed lee's Avatar
any more comment and more detil pls........maybe some pic that will be nice..........
Old 04-14-2006, 05:36 AM
98DC2-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed lee &raquo;</TD></TR><TR><TD CLASS="quote">just replace the usdm steering to a jdm "non-airbag" steering.....want to know how to make the "srs" light off......pls help....... </TD></TR></TABLE>
The easiest way is to pull out your instrument cluster and unplug the yellow plug out of the back.. As long as the air bag is not present the computer can't be reset.. If I remember correctly if the light is on the passenger's side bag will not deploy either.. Another option is to simply unplug the main harness from the SRS ecu located under the heater box in the front center dash... not exactly legal though in some states to do this i don't think...
Old 04-14-2006, 05:45 AM
ITR764's Avatar
Default Re: how to turn off the "srs" light.......pls help (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">Or just pull the bulb </TD></TR></TABLE>
Old 04-14-2006, 06:15 AM
aziantegger10's Avatar
Default Re: how to turn off the "srs" light.......pls help (98DC2-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98DC2-ITR &raquo;</TD></TR><TR><TD CLASS="quote">
The easiest way is to pull out your instrument cluster and unplug the yellow plug out of the back.. As long as the air bag is not present the computer can't be reset.. If I remember correctly if the light is on the passenger's side bag will not deploy either.. Another option is to simply unplug the main harness from the SRS ecu located under the heater box in the front center dash... not exactly legal though in some states to do this i don't think...</TD></TR></TABLE>
never new that if the light was on the pass. airbag would not work...guess its time for a jdm block off tray
Old 04-14-2006, 06:29 AM
BudMan's Avatar
Default Re: how to turn off the "srs" light.......pls help (aziantegger10)
I've always been curious why everybody wants the jdm blockoff tray. They usdm cover fits right back on after removing the airbag...maybe it's the jdm bling virus & I just haven't been infected yet.
Ra GS-R
07-15-2007 01:12 PM
92ehatch
07-30-2006 05:57 PM
ososlow24
11
11-04-2004 05:16 AM
GreenEX
36
03-10-2004 04:36 PM
Quick Reply: how to turn off the "srs" light.......pls help
