how is timing effected?
Old Apr 17, 2002 | 07:57 PM
Rob :190:'s Avatar
Default how is timing effected?
yo fellas,
a friend of mine, who is on the board, but is too much of a pansy to make his own thread, has a question. How does a aftermarked headgasket effect ignition timing? retard? advance? no difference? just tryin to get his motor runnin like it should, the previous owner installed a mugen headgasket. thanks guys
edit: what about cam timing?
[Modified by Brian Spilner 1035, 11:58 PM 4/17/2002]
Old Apr 17, 2002 | 08:03 PM
Tommy_Gunns's Avatar
Default Re: how is timing effected? (Brian Spilner 1035)
Check the ignition timing with a timing light. In my opinion, a mugen head gasket (we are talking fraction of a mm difference) is not going to affect ignition timing all that much.
Old Apr 17, 2002 | 08:24 PM
C-speed's Avatar
It doesn't affect ignition timing.. it affects your cam timing. For every 0.010" you reduce in the block to head distance, you need to advance the cams by 1degree to compensate.
Old Apr 17, 2002 | 09:37 PM
sgT's Avatar
sgT
Default Re: how is timing effected? (G3-TEG)
But since the intake cam directly affects the ignition timing, the same applies
for ignition timing, UNLESS you move the intake cam to compensate instead.
Old Apr 17, 2002 | 09:47 PM
C-speed's Avatar
Default Re: how is timing effected? (sgT)
Your right... i was refering to the direct relationship between the two.
Treyschls
Apr 13, 2023 07:04 AM
kirkland08
Feb 13, 2011 08:59 AM
johnwohl
Apr 1, 2008 07:29 PM
Mugen_DC2R
Jun 18, 2007 08:04 AM
donnjuan2point2
Mar 11, 2004 10:49 AM
