How to remove the steering column?
Old Feb 29, 2004 | 08:58 AM
EGRhatch's Avatar
Default how do you remove the steering column??
I am buying a steering column and the guy taking it out is a little confused, he sent me this PM <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">big problem I need to know what tools you guys used to get those parts out cause I can't get my drill towards the back under that lip part to drill out the rest of the welds</TD></TR></TABLE> can anyone help me out... he just needs to get the steering column out so I can put ti in my car. Thanks
Old Feb 29, 2004 | 08:19 PM
EGRhatch's Avatar
Default Re: how do you remove the steering column?? (EGRhatch)
somone help me out
Old Mar 3, 2004 | 07:59 AM
spoonef's Avatar
bump for this guy
Old Mar 3, 2004 | 08:03 AM
splitime's Avatar
Steering column (not support) = remove the dash pieces below it. unhook all the electrical stuff, if srs make sure to do the safety plug in the back of the wheel. Take wheel off. Take column covers off. take cover around the column, under the dash off. There should be two bolts holding it to the steering column support and one holding it to the rack down by the firewall. Thats about it.
Also, make sure blinker switches are included in the unplugging stuff and removed, srs spindle removed. Careful when unplugging the ignition, when those things ground they arc ..... might want to make sure battery is disconnected.
Old Mar 3, 2004 | 08:27 AM
JeffS's Avatar
I can't imagine what the guy is trying to drill. The steering column bolts in.
Remove one bolt at the universal joint.
Remove two bolts at the lower column mount, and two bolts at the upper column mount.
That's it.
Old Mar 3, 2004 | 08:33 AM
MattD@Stoptech's Avatar
Default Re: how do you remove the steering column?? (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">I can't imagine what the guy is trying to drill. The steering column bolts in.
That's it. </TD></TR></TABLE>
Plus a couple of electrical connectors...those don't require a drill to remove either though
Old Mar 8, 2004 | 04:16 PM
EGRhatch's Avatar
Default Re: how do you remove the steering column?? (El Pollo Diablo)
thanks for the help guys... I really appreciate it
Old Mar 10, 2004 | 06:45 PM
bracket 4 life's Avatar
I am trying to take out the steering column support bracket, not the steering column itself, I already go that out
thekid2390
Mar 30, 2013 02:57 PM
AJxr
Jan 8, 2006 11:08 AM
RicharDC4
Jun 1, 2005 03:21 AM
Eg_Lover
Jul 15, 2004 04:50 AM
Nextelbuddy
Jun 22, 2003 09:01 AM
