How can you tell if your suspension is damaged?
Old 04-21-2002, 12:29 PM
ncitrdude's Avatar
Default How can you tell if your suspension is damaged?
Last friday i got into an accident where my left front tire hit a curb at around 10-15 mph (i was braking hard). THe car drives fine, but the alignment is off (to go straight, the wheel has to turned about 25 degrees right of center). THere is no vibration at highway speeds. Does this sound like permanent suspension damage? Which component of the suspension would most likely be damaged if it were?
Unrelated to the suspension, the AC has stopped working. If you turn the AC on, a whirring sound (with a faint metallic scraping sound) happens. What does this mean?
Any insight would be greatly appreciated....
Jason
'00 FBP #1297
Old 04-21-2002, 12:33 PM
johnzm's Avatar
Default Re: How can you tell if your suspension is damaged? (ncitrdude)
align it. an alignment will probablt fix it
Old 04-21-2002, 12:34 PM
ncitrdude's Avatar
Default Re: How can you tell if your suspension is damaged? (johnzm)
you don't think a suspension component was bent from the impact?
Old 04-21-2002, 12:38 PM
R0476's Avatar
Probably the alignment, I hit a giant rock about the size of a beer bottle going 70mph in my Civic. Bent the rim slightly and blew a hole in the tire, alignment fix the streering. You might have a blown shock though because thats what I felt before I sold the car.
qazaq
11-13-2009 04:49 AM
IgnitionZ05
03-18-2007 09:54 AM
krazyhmongboi
25
01-05-2007 05:29 AM
lude-tec
Suspension & Brakes
03-31-2006 12:49 PM
Quick Reply: How can you tell if your suspension is damaged?
