How to bleed the radiator fluid
Re: How to bleed the radiator fluid (wantmorepower)
Fill at radiator cap, open bleed screw at the water neck - leave radiator cap off. You'll see the coolant bubbling out (catch it with a towell/rag), when it stops bubbling out (just comes out steady) then put the cap on and run the engine till its hot (fan comes on) with the header **** set all the way hot, check to see if you need to add coolant.
Re: How to bleed the radiator fluid (.RJ)
I did mine a couple of months ago - I found all the info on here and collated into a document :-
http://www.munc.co.uk/bentemp/coolant%20change.doc
let me know when you have got it as this isnt my webspace i have uploaded it to.
Ben.
Ben.
miahjera04
09-05-2018 04:19 PM
