Help!!Solid cel
Old Aug 13, 2005 | 09:17 AM
JDM97R's Avatar
Default Help!!Solid cel
Hi guys,I just swapped a jdm b18c type r engine in a 1992 model civic.
The problem is that i'm getting a solid cel and main relay is not working.
When i turn the ignition on the cel comes on and remains on.
What can it be? Can somebody help me please?
I also swapped the interior harness with an si model and the car was with abs and the new harness i put has no abs.
Could it be a problem that it is w/o abs now?
Old Aug 13, 2005 | 09:49 AM
RagingAngel's Avatar
Default Re: Help!!Solid cel (JDM97R)
http://www.c-speedracing.com/faq/06.php
Old Aug 13, 2005 | 09:53 AM
JDM97R's Avatar
Default Re: Help!!Solid cel (RagingAngel)
I know how,but it is a solid cel
Old Aug 13, 2005 | 10:23 AM
does the car drive normal?
Old Aug 13, 2005 | 04:42 PM
JDM97R's Avatar
It is not starting.
Fuel pump is not working either the fuel pump relay
Old Aug 13, 2005 | 09:48 PM
mugenracer's Avatar
Solid CEL means a problem with the ECU itself. Which one are you using? Try and get hold of a known working ECU and see if your getting the same problem...if you are you need to recheck all the ECU wiring, especially the live and ground wires.
Old Aug 13, 2005 | 11:47 PM
JDM97R's Avatar
Default Re: (mugenracer)
The ecu is good .I checked it on another car.I'm using a chipped p28
Old Aug 13, 2005 | 11:49 PM
gaydm.accord's Avatar
did you jump it for codes? unless your saying thats the code your getting is a solid ecu. try checking your ecu fuse.
Old Aug 13, 2005 | 11:56 PM
JDM97R's Avatar
Default Re: (gaydm.accord)
All the fuses are good.I double checked them
the.tetrix
Aug 15, 2017 03:58 PM
mr_munro
Engine Management and Tuning
Mar 25, 2012 04:41 PM
JDM97R
Aug 14, 2005 12:04 PM
Redsun
Aug 26, 2004 06:22 AM
LostAndFound
Aug 12, 2004 11:09 AM
