help no VTEC??????
Old Jul 11, 2003 | 10:13 PM
snake01's Avatar
Default help no VTEC??????
I just got my new head back, I got it ported poilshed new valves, springs, retainers, it's a b16 head on my b18c5 bottom end. The new head was put on, but now I have no vtec the car wont engage I have did everthing. I even hooked up a test light to the vtec seilnoid plug and carried it around in the car to see if I was getting voltage to the seilnoid, I was getting power becuase when vtec was supose to engage the light would come on. I have no Idea what to do now I have tried everthing it almost seems like there is no oil geting to the vtec selinod I dont know someone please help.
Old Jul 11, 2003 | 10:17 PM
JDM CTR '00's Avatar
Default Re: help no VTEC?????? (snake01)
well do you have enough oil? lol
Old Jul 11, 2003 | 10:33 PM
TypeR 01 886's Avatar
Default Re: help no VTEC?????? (JDM CTR '00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR '00 &raquo;</TD></TR><TR><TD CLASS="quote">well do you have enough oil? lol</TD></TR></TABLE>
check your oil presssure......................................... ..
Old Jul 11, 2003 | 10:46 PM
B2FiNiTY's Avatar
Definately check your oil while the motor is cold and on level ground. Please report your findings.
Old Jul 11, 2003 | 11:19 PM
RockstarJR's Avatar
oil???
Old Jul 12, 2003 | 02:39 AM
.RJ's Avatar
.RJ
Default Re: help no VTEC?????? (ITRChris)
Also Check:
MAP
Coolant Temp
TPS Ground
Old Jul 12, 2003 | 06:29 AM
snake01's Avatar
Default Re: help no VTEC?????? (.RJ)
plenty of oil, my other question is the journal holes of a b18c5 head gasket different then a b16a head gasket.
Old Jul 12, 2003 | 06:48 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snake01 &raquo;</TD></TR><TR><TD CLASS="quote">plenty of oil, my other question is the journal holes of a b18c5 head gasket different then a b16a head gasket.</TD></TR></TABLE>
Nope. Time to get our your multimeter.
Old Jul 12, 2003 | 01:42 PM
Jackson's Avatar
Are you getting any engine codes? It might be possible that you switched the ect sensor plug with the vtec pressure switch plug.
Old Jul 12, 2003 | 02:16 PM
sackdz's Avatar
It is a mechanical problem, not electrical. There is voltage at the VTEC solenoid at the crossover RPM. We tried 2 different VTEC solenoids. All oil orifices are in place. There are no flow restrictions through the rocker rods.
Oil level is fine.
How is the VTEC solenoid fed with oil? There are 5 ports on the head where the solenoid mounts and 1 is the output to the rockers. What are the other 4?
Old Jul 12, 2003 | 02:30 PM
Hooch'n's Avatar
Default Re: help no VTEC?????? (sackdz)
ground.....not sure.
Old Jul 12, 2003 | 08:20 PM
snake01's Avatar
Default Re: help no VTEC?????? (Hooch at 8400-RPM)
I belive it is in the head somewhere I just dont know where.
Ryan.
Oct 12, 2005 09:11 AM
fabe85
Nov 27, 2004 11:30 PM
5ltreater
Sep 27, 2004 07:22 PM
1boostedgsr
Aug 4, 2004 03:21 PM
untitled
Aug 13, 2003 10:37 AM
