vtec not working (help)
Old Aug 2, 2004 | 11:29 PM
1boostedgsr's Avatar
Default vtec not working (help)
I cant hear or feel vtec working. What are some things I can check to figure out the cause of it. Ever since I went turbo vtec has not been working. Any help would be great.
Old Aug 2, 2004 | 11:55 PM
gsrfrancisco's Avatar
Default Re: vtec not working (1boostedgsr)
check your oil level if your oil pressure isnt high enoufgh it woulnt pop let me know how it goes
Old Aug 3, 2004 | 12:09 AM
LSTEG96's Avatar
Default Re: vtec not working (gsrfrancisco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrfrancisco &raquo;</TD></TR><TR><TD CLASS="quote">check your oil level if your oil pressure isnt high enoufgh it woulnt pop let me know how it goes</TD></TR></TABLE>
heres a thought... maybe ur burning mad oil... and ur level is low, which would cause vtec to not work, AND cause u to run 14.3 on 8lbs... ?
edit: meaning u have no rings left so ur not making power (14.3) and then it burns the oil (no vtec (even LESS power)).
Old Aug 3, 2004 | 12:32 AM
3.504's Avatar
Default Re: vtec not working (LSTEG96)
if you're low enough on oil to not activate vtec... i wouldn't turn the engine on. especially w/ an oil cooled turbo... you could smoke bearings in block and turbo and that would be a HUGE expense. are you throwing a CEL (check engine light)? if so: whats the code? theres all sorts of things you should be checking out.
and yes, 14.3 w/ 8psi doesn't sound right, thats either a horrible tune, or you have some problem.
Old Aug 3, 2004 | 04:46 PM
Default Re: vtec not working (3.504)
I am throwing a cel. I dont know if I did the jumper right. When I broke it down the code was something to do with automatic transmission code. Ill check again.
Old Aug 3, 2004 | 04:50 PM
RallyRedGT-V6's Avatar
yea..you must've just read the code wrong...seeing how your pulling an auto tranny code when you have a stick
Old Aug 3, 2004 | 06:02 PM
Deep's Avatar
did you check if the solenoid is good? throw a 12v through it and it should click, if it doesnt than your problem is a bad solenoid. If your car wasnt originally Vtec double check your wires. good luck with it, 1!
Old Aug 4, 2004 | 03:21 PM
Default Re: vtec not working (Deep)
What do you mean by trowing a 12 v to it. It is stock vtec. Ill check the code again tonight, then reply back.
Thanks
Also Im not burning or leaking oil
tigasin
Nov 14, 2008 11:58 PM
tuan...
May 7, 2008 12:09 PM
Ryan.
Oct 12, 2005 09:11 AM
fabe85
Nov 27, 2004 11:30 PM
PlikityPLAH
Oct 3, 2004 07:01 PM
