Help!
Im replacing my timing belt on my 2000 ITR. I couldn't break the tensioner bolt loose(it hasn't ever been touched untill now.I broke 3 sockets, then tried a chizzle and now the head on the bolt is messed up. Any advice?
you used a chisel on it?! what for?
any chance you can get some vicegrips on it and then use a pipe or something to give better torque/leverage? how did you break 3 sockets?
otherwise, the only thing I can think to do is to maybe drill a hole in it and use a screw extractor..
i assume you soaked it in PB blast(or equivalent) after you initially had trouble removing it?
it's not reverse threaded or locked in some way is it? i can't remember offhand..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by encognito »</TD></TR><TR><TD CLASS="quote">Im replacing my timing belt on my 2000 ITR. I couldn't break the tensioner bolt loose(it hasn't ever been touched untill now.I broke 3 sockets, then tried a chizzle and now the head on the bolt is messed up. Any advice?</TD></TR></TABLE>
Bolt extractor. Or at least get an impact socket so you stop breaking them.
http://www.irwin.com/irwin/con...00005
Theres no way to get an ipmact on that without droping the motor.
That's why I think he has the wrong bolt because you cant really get a chisel on it either. Not that chisels turn bolts anyway lol..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz »</TD></TR><TR><TD CLASS="quote">Theres no way to get an ipmact on that without droping the motor.
That's why I think he has the wrong bolt because you cant really get a chisel on it either. Not that chisels turn bolts anyway lol..</TD></TR></TABLE>
I've seen impact ratchets that'll do 100+ ft-lb... but seriously... umm...
LEFTY LOOSEY RIGHTY TIGHTY!
-Chris
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz »</TD></TR><TR><TD CLASS="quote">Not that chisels turn bolts anyway lol..</TD></TR></TABLE>
that's what i was getting at.. lol..
You did remove the p/s belt from the p/s pulley right? Or at least, lowered that part? If not, it's very hard to get anything on that bolt. I hadve busted my hand countless times w/that bolt. I think it always hit the mount or something, ha.
air chisels are 'very' effective when removing stubborn crank pulley bolts..
seeeya04
Nov 24, 2005 03:25 PM
kpringcivic
11
Oct 21, 2005 07:18 PM
kess
37
Dec 2, 2004 09:21 AM
Ignitecivic
21
Dec 23, 2003 04:03 AM
