Header Help: Torque Spec on the bolts to the Engine
Old Mar 1, 2002 | 12:13 PM
PiYoImuT's Avatar
Default Header Help: Torque Spec on the bolts to the Engine
Quickie help... the Torque Spec for bolts that holds the header to the engine block..
thanks.
Old Mar 1, 2002 | 12:16 PM
Mike K's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (PiYoImuT)
Until they are tight. That's what I do.
Book says 20 ft/lbs.
Old Mar 1, 2002 | 01:28 PM
typealex2's Avatar
My book states 23 lbf-ft,31N-m. No big difference, should be fine either way.
Old Mar 1, 2002 | 04:41 PM
GRM Scott's Avatar
25 Year Member
Default Re: Header Help: Torque Spec on the bolts to the Engine (Mike K)
does the helm state this anywhere? also, why does the pic of the B18C5 show bolt studs for every hole on the header? we got it on, everything went well, thanks for quick help
Old Mar 1, 2002 | 04:52 PM
Teepo's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (Aleph)
23 ft lbs
Old Mar 1, 2002 | 04:55 PM
TypeR 599's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (ITR1150)
23 ft lbs
how can you tell if you tightened it enough? what type of wrench should be used for this job?
Old Mar 1, 2002 | 05:19 PM
B2FiNiTY's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (TypeR 599)
Um... a Torque wrench?
Old Mar 2, 2002 | 01:25 AM
Art Vandeleigh's Avatar
23 ft lbs
are you serious??
Old Mar 2, 2002 | 09:22 AM
TypeR 599's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (cali-r)
err....i dont have a torque wrench, i got air tools and reg socket wrenches...
Old Mar 3, 2002 | 01:43 AM
what kind of air tools do you have?? how many different kinds do you need to work on a car??? you use air tools but you dont know what a torue wrench is?
Old Mar 3, 2002 | 05:18 AM
SlayANT's Avatar
23 ft lbs
are you serious??
ROLF ... Oh man..that made my morning.
Old Mar 3, 2002 | 06:15 AM
primoEF's Avatar
you are not serious right? You want to torque spec for the header, just use a wrench
Old Mar 3, 2002 | 09:48 AM
Bbasso's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (b18k1)
All of you got me laughing...
air guns, torque specs and ratchets....
Blahhhhh hahaha
Old Mar 3, 2002 | 10:08 AM
B2FiNiTY's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (Bbasso)
Hahaha. Poor neener.
Old Mar 3, 2002 | 02:05 PM
mugenr#1011's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (B2FiNiTY)
lol!!!!
Old Mar 3, 2002 | 02:14 PM
TypeR 599's Avatar
i have no access to a torque wrench and no experience with one, so you think it would be enough to just use a wrench? will that do the job?
the air tool i use just tightens and loosen bolts quicker so i dont know how tight it will make the bolts...geez...
glad my inexperience is making your day guys... ..thanks for the help
Old Mar 3, 2002 | 02:18 PM
fast-R's Avatar
New User
You'd be better off using hand tools rather than the air to tighten it if you don't have access to a torque wrench. You can get an ultra cheap torque wrench for what, like $20 or so.
Old Mar 3, 2002 | 02:20 PM
TypeR 599's Avatar
Default Re: Header Help: Torque Spec on the bolts to the Engine (fast-R)
wow thanks fast-R . so do you think manually tightening it will be enough?
Old Mar 3, 2002 | 04:51 PM
B2FiNiTY's Avatar
Manually should be fine but I would tq it down just to be safe. I also have a cheap TQ wrench that I used once. It's ghetto as hell but I'll let you borrow or buy if you want. $10
NSfit
Honda Fit
Jan 2, 2009 07:57 AM
OpTiMo MoToR
Honda Civic (2001 - 2005)
11
Nov 29, 2006 08:04 PM
dohc-nyne
Sep 11, 2003 03:21 PM
MintyDip
Aug 2, 2001 06:52 PM
