Having problems with idle....
Old Nov 20, 2002 | 09:10 AM
done's Avatar
Default Having problems with idle....
My car idles funny now. it goes from 2k, to 1.5k and then down to 1.1k rpms. it does jump when motor is cold..
I think its the tps or iacv..
Anyone knows how much these will be to replace, my fking warrenty just went up in october..
anyone have a tps or iacv?
Old Nov 20, 2002 | 09:13 AM
gblaue's Avatar
Default Re: Having problems with idle.... (Jordo)
I had a coolant emp sensor go bad and cause that symptom.
Old Nov 20, 2002 | 09:19 AM
done's Avatar
Default Re: Having problems with idle.... (00ITR#756)
how did you fix it and how much was it?
Old Nov 20, 2002 | 09:27 AM
gblaue's Avatar
I just ordered a new coolant temp sensor and replaced it. I think it was like $50. There are several thing that can cause this. You need to check to see if a code has been stored before you start spending money unnecessarily.
Old Nov 20, 2002 | 09:30 AM
done's Avatar
k
Old Nov 20, 2002 | 09:37 AM
stRtypR25's Avatar
by code do you mean check engine light code? b/c i am have the same problem too
Old Nov 20, 2002 | 09:42 AM
gblaue's Avatar
Default Re: Having problems with idle.... (stRtypR25)
Yep, just because it isn't illuminated, that doesn't mean one hasn't been stored.
Old Nov 20, 2002 | 09:43 AM
done's Avatar
ill check it
Old Nov 20, 2002 | 10:53 AM
done's Avatar
only detected my test pipe... no other..
Old Nov 20, 2002 | 12:31 PM
done's Avatar
ok im clueless, it cant be my tps because it hasnt throw a code.. where is the iacv located...
Old Nov 20, 2002 | 02:52 PM
gblaue's Avatar
Aree you still using both O2 sensors?
Old Nov 20, 2002 | 03:27 PM
tjtruong's Avatar
New User
i have the same problem, but haven't been able to fix it yet cuz i've been busy with hospital stuff, but here are some links to look at. I'll message you when i get mine fixed to see if helps any. Here you go. Have fun. Let me know when you fixd it also. Thanks
https://honda-tech.com/zerothread?id=304013
and
https://honda-tech.com/zerothread?id=298981
Thomas
Old Nov 20, 2002 | 07:12 PM
done's Avatar
Default Re: Having problems with idle.... (tjtruong)
and
Thomas
thanx man, im ognna give it a try..
Old Nov 20, 2002 | 08:34 PM
tjtruong's Avatar
New User
and
Thomas
Old Nov 21, 2002 | 05:50 PM
done's Avatar
when i let off the gas now.. it sputters...
this weekend, im gonna disamble the whole thorrtle body and cleaning it..
hopefully tomorrow we can fix it..
Old Nov 22, 2002 | 10:14 PM
done's Avatar
figured out the problem, bad pvc valve, replaced it with a ls one. and it runs alot better, but still messed up. soo mi going to acura tomorrow to get a type r one
Old Nov 22, 2002 | 10:16 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
what are your mods? that would help if some smart people (not me) decided to weigh in on this...
Old Nov 23, 2002 | 02:44 AM
Reid's Avatar
Global Moderator
How can you say you figured out the problem when the car is "still messed up"?
The LS and ITR PVC valve is the same.
You've already tried doing regular maintenance (replacing cap, rotor, spark plugs) to see if that got rid of the problem, right?
Probably the best thing to do in your situation is to take the car to someone that knows what they're doing before you waste more money replacing parts that weren't broken.
Old Nov 23, 2002 | 11:03 AM
done's Avatar
Default Re: Having problems with idle.... (Ross)
i think its a combinatoin, of my pcv valve, my intake manifold gasket is ripped (i can see it)....
soo we gonna put my hondata gasket in..
does the hondata gasket replace the factory one?
Fantastic420
Oct 7, 2009 12:16 PM
smokinsi
Jul 18, 2004 05:09 PM
AmauryR
Mar 4, 2002 08:45 AM
GSRwBOOST
Jul 12, 2001 06:07 AM
