car problem
Old Jul 11, 2001 | 10:29 PM
GSRwBOOST's Avatar
Default car problem
Well tonight I rolled up next to a cobra svt... next thing i know there's a cop, so I move out of the way.. and wehn I get to the next light.. after a little boost...
the car idles up and down between 1400 and 1000 vroomvroomvroomvroom.. now i'm assuming it's in panic mode, got a CEL but havnt checked the code out yet...
before i get the code.. am i correct in thinking it's in panic mode.. cause i sure am...
Old Jul 11, 2001 | 10:30 PM
VaporTrail's Avatar
New User
Default Re: car problem (GSRwBOOST)
sounds like you blew off something, and it's leaking past the TB. Check the code, I think code 3 is MAP sensor, that's just my guess.
Old Jul 11, 2001 | 10:44 PM
GSRwBOOST's Avatar
Default Re: car problem (VaporTrail)
thanks.. i'll check that in the morning.. before work.. and look for a vacume leak.. i also noticed the fuel pressure was higher than normal at idle so your prolly right about that.. I pray that's all it is!!!
Old Jul 12, 2001 | 04:49 AM
GSRwBOOST's Avatar
codes 14 and 63..
not sure why.. gonna reset the ecu and see what happens.
Old Jul 12, 2001 | 04:52 AM
Arturbo's Avatar
Better than steak
25 Year Member
14= Idle controll sys (IAC, Fast idle thermo valve)
63= secondary O2. I used to get that one all the time untill I changed to 96 ecu.
art
Old Jul 12, 2001 | 04:57 AM
GSRwBOOST's Avatar
Default Re: car problem (Arturbo)
i translated the codes as a bar map sensor and o2 sensor..?? off this one site..
i reset the ecu and it's idling now.. not sure what caused it? idle is fine now.. we shall see what happens.. gonna drive it for a bit before i head off to work..
whats an IAC?
Old Jul 12, 2001 | 05:08 AM
Arturbo's Avatar
Better than steak
25 Year Member
IAC= idle air control. it could also be a leak in the vacum lines or the intake manifold.
art
Old Jul 12, 2001 | 06:07 AM
Evil DOHC's Avatar
Check your fuel pressure regulator and the vacum line conected from the manifold to the regulator. U also mentioned that your fp went up. A tiny hole in the hose can cause large problems.
EVIL
OldTL
Acura TL, RL & ZDX
Jul 30, 2017 03:12 PM
hecubus
Feb 26, 2007 03:07 PM
92eg6_pino
Aug 16, 2005 07:53 PM
