Grinding while downshifting
Old May 3, 2004 | 04:25 PM
cr00klyn718's Avatar
Default Grinding while downshifting
A friend of mines just finished putting a b18c-r into his ek and he had a grind while downshifting from 3rd to 2nd at mostly any rpm...and we're trying to figure out what can cause this grind......i would understand shifting up from 1st to 2nd to 3rd etc etc..from hard driving...but basically we wanna know what can cause this type of grind.
thanks
Old May 3, 2004 | 04:26 PM
.RJ's Avatar
.RJ
Default Re: Grinding while downshifting (cr00klyn718)
Bad synchro.
Learn to double-clutch.
Old May 3, 2004 | 05:35 PM
Default Re: Grinding while downshifting (.RJ)
So that can also be cause by starting out on 2nd also?
Old May 3, 2004 | 05:38 PM
redsivik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Bad synchro.
Learn to double-clutch.</TD></TR></TABLE>
yea double-clutching is what driving a manual all about.
Old May 3, 2004 | 05:49 PM
Default Re: Grinding while downshifting (redsivik)
So basically he's ok? no need to fix the tranny/synchro as long as he double-clutch while downshifting it will be fine and not get worst
Old May 3, 2004 | 05:53 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr00klyn718 &raquo;</TD></TR><TR><TD CLASS="quote">So basically he's ok? no need to fix the tranny/synchro as long as he double-clutch while downshifting it will be fine and not get worst </TD></TR></TABLE>
In theory. But you'll need to replace it.
Old May 5, 2004 | 06:05 PM
Ne body know generally how much to fix the 1-2nd synchros?(labor + part)
Old May 6, 2004 | 03:21 AM
uNF$@#!'s Avatar
part is expensive, and the labor is equally expensive.
Old May 6, 2004 | 03:41 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr00klyn718 &raquo;</TD></TR><TR><TD CLASS="quote">Ne body know generally how much to fix the 1-2nd synchros?(labor + part) </TD></TR></TABLE>
$500 in parts roughly for the synchro, gear, other **** you might need to replace while its apart.
Add whatever labor ($500 or more probably) and if you do a new clutch at the same time thats even more.
Old May 6, 2004 | 04:19 AM
Dan GSR's Avatar
Add whatever labor ($500 or more probably) and if you do a new clutch at the same time thats even more.</TD></TR></TABLE>
wonder how you came up with a response so quick
Flux
Dec 4, 2006 07:25 PM
superhatchbackbros
10
May 30, 2006 10:19 PM
Kyles ej1
100
Aug 6, 2004 07:16 PM
ComingSoonNearYou
13
May 23, 2004 05:12 PM
io_burn
Apr 25, 2003 07:13 PM
