Getting to 9.2k
Old Jul 31, 2002 | 01:24 PM
Junglist's Avatar
Default Getting to 9.2k
What does it take to safely rev to 9.2? What do I need to upgrade on the inside? Springs and retainers? Then I just need to reprogram my ecu, correct?
I want to stay "close" to stock; however, I'm getting the jdm final drive, and do not want to see a dip in the top speed.
thanks.
Old Jul 31, 2002 | 01:28 PM
96 SOHC VTEC's Avatar
Default Re: Getting to 9.2k (Junglist)
Top speed? How often do you go 140mph?
Old Jul 31, 2002 | 01:29 PM
01PYITR's Avatar
If you stay stock It might not be able to rev that high (limiter) and you will have no more power past 8450, so why would you want to rev?
Old Jul 31, 2002 | 01:32 PM
type r 01-1063's Avatar
Default Re: Getting to 9.2k (96 SOHC VTEC)
I think he means top speed at each gear.
i.e. 1st 40mph, 2nd 60mph, 3rd 90mph
Junglist's Avatar
Default Re: Getting to 9.2k (01PYITR)
I just don't want to get too crazy with the internals. I plan on something like this:
I-mugen/H-toda/E-custom, Lowdowns, skunk2 adj cam gears (stock cams), fpr + rail/lines/injectors, jdm final drive, Portflow head work, hondata
Old Jul 31, 2002 | 01:34 PM
Junglist's Avatar
Default Re: Getting to 9.2k (type r 01-1063)
yup, I don't want to have to shift as quickly.
[Modified by Junglist, 2:38 PM 7/31/2002]
Old Jul 31, 2002 | 02:24 PM
Def's Avatar
Def
Why all the concentration on fuel(rail + injectors) when you are still using stock cams?
IMO, spend the money you'd spend doing that, and then go with some bigger bumpsticks to actually make power out to 9k RPM. At least Toda Spec A's if you want a stockish feel.
Old Jul 31, 2002 | 02:32 PM
Junglist's Avatar
Default Re: Getting to 9.2k (Def)
It was my understanding that after you add air you would want to give it a little more gas to even things out. Is that wrong?
Stock cams don't make power past 8.5? I'm igrnorant, please help.
Old Jul 31, 2002 | 03:01 PM
B2FiNiTY's Avatar
Stock cams don't make much power past the stock redline.
Adding all that fuel I have heard is unnecessary with stock to mild cams. It may add more power and be good for tuning but the money may not be worth it.
Old Jul 31, 2002 | 03:02 PM
4-1-1's Avatar
thats no where near stock....
Old Jul 31, 2002 | 03:06 PM
Oh. My bad.
Old Jul 31, 2002 | 03:10 PM
Doctor CorteZ's Avatar
Default Re: Getting to 9.2k (4-1-1)
still stock bumpsticks and last time I checked they dont make power past 8400.
Old Jul 31, 2002 | 03:11 PM
Junglist's Avatar
Default Re: Getting to 9.2k (Doctor CorteZ)
so it's all or nothing...damn
maybe i can deal with quick shifts or no final drive.
Old Jul 31, 2002 | 03:18 PM
B2FiNiTY's Avatar
Why don't you just get I/H/E. FPR, cam gears. Leave the internals alone. Also get the JDM FD and a flywheel. Hondata is always good. MaD sHiFtInG sKiLLz y0!
[Modified by B2FiNiTY, 4:19 PM 7/31/2002]
Old Jul 31, 2002 | 03:20 PM
Reid's Avatar
Global Moderator
Stock cams are making power at 9100rpm which is about as high as you can rev on stock valvesprings.
Where are you guys getting your info?
Old Jul 31, 2002 | 03:23 PM
done's Avatar
jun 3s or toda bs
Old Jul 31, 2002 | 07:37 PM
Default Re: Getting to 9.2k (Reid)
really..............
every plot I've ever seen theose things drop like a rock after 8400
not questioning you at all , just didnt know
99CoupeEK
Feb 21, 2019 10:45 AM
kop-O-nen
Jan 2, 2010 11:45 AM
November5th
13
Feb 17, 2007 10:27 AM
SupamaN8832
Jun 28, 2004 06:12 AM
austrian type-R
Feb 28, 2002 05:33 AM
