Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
- General Information and Maintenance Schedule
Important information to help you understand your Honda
FAQ: Acura Recommended Maintenance Schedule
<u>7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service</U>
Change Engine Oil & Filter
Check Clutch Adjustment & Fluid Level
Inspect Front Brake Pads, Rotors and Calipers
Inspect Fluid LEvels
Adjust Parking Brake
Inspect Exhaust System
Inspect Tire Wear & Set Tire Pressure
Check hoses, belts & coolant level
check wiper blades & windshield washer fluid level
inspect power steering fluid level
inspect transmission fluid level
inspect front suspension & steering operation
rotate tires
<u>15k/45k/75k mile service</U>
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Inspect Front & rear Pads, Rotor & calipers
Inspect all fluid levels
adjust parking brake
inspect clutch operation, adjust freeplay and check fluid level condition
adjust all belts
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
check hoses belts and coolant level
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and winshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
inspect and clean spark plugs
inspect cap and rotor
road test
<u>30k/60k/90k mile service</U>
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace Distributor cap, rotor and inspect wires
set ignition timing and adjust cambelt
Inspect crankcase emissions
Inspect front & rear pads, rotors and calipers
Replace brake fluid, check hoses & lines
replace clutch fluid, clutch operation, adjust freeplay
adjust all belts & inspect power steering fluid
replace engine coolant & check hoses belts
check wiper blades and windshield washer fluid
[Modified by Soup ****, 6:20 PM 7/6/2002]
Re: FAQ: Acura Recommended Maintenance Schedule (zyg)
This is all in the owners manual, isn't it.
I shoot brides
Re: FAQ: Acura Recommended Maintenance Schedule (00-0187)
daym, that's a lot of typing
I'll FAQ this when I get to work tomolo
yshi - who just got back from The Block w/ 234 in one piece
Re: FAQ: Acura Recommended Maintenance Schedule (Zygspeed)
way to help out the lazy asses
LOL!
I don't see the clean and lube of the antenna.
LOL!
Re: FAQ: Acura Recommended Maintenance Schedule (Soup ****)
Page 129 of my 97 Owner's Manual lists "Clean antenna mast" under the severe condition maintenance schedule @ 15 K mile increments.
Other than that, you've pretty muche covered everything else.
P.S. -- Oddly enough it also says that Canadian owners should follow the severe maint. schedule.
Change Tranny Fluid
Change Tranny Fluid
Re: FAQ: Acura Recommended Maintenance Schedule (stormywaters)
I'd never thought i'd see this thread brought up again.
if you have the rear spare jack in the car, you can change the tranny fluid.
well... i do have the rear spare jack, so i guess i can do it myself. what size tool do i need? any tricks i need to know? how much honda tranny fluid do i need to pick up?
[Modified by stormywaters, 3:36 AM 3/2/2003]
1 liter will do.
do a search, lots of times this has been put up.
basically theres a drain/fill plug. i think they are 19/17mm respectively, but with my forgetful mind, better look it up.
torque wrench, and a tube/funnel to feed the fluid in. thats it.
if you dont feel confident doing this, just goto the dealer and have them do it.
its a no brainer, but some people arent cut out for even this sort of work. good luck. i believe theres a page on c-speedracing.com that covers this.
[Modified by Soup ****, 10:56 PM 3/1/2003]
edit: (one year later) : i cant believe i said 1 liter....prolly closer to 2-2.2 quarts
Modified by Soup **** at 12:50 AM 1/26/2004
Modified by Soup **** at 12:51 AM 1/26/2004
wow, OLD thread.
Tranny fluid change is so easy, even I can do it.
Check out the 'how-to' section on c-speedracing.com like Master Soup said.
BTW - is/are the c-speedracing person/persons on h-t??
io_burn
08-20-2003 02:29 AM
