FAQ: Acura Recommended Maintenance Schedule
<u>7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service</U> Change Engine Oil & Filter Check Clutch Adjustment & Fluid Level Inspect Front Brake Pads, Rotors and Calipers Inspect Fluid LEvels Adjust Parking Brake Inspect Exhaust System Inspect Tire Wear & Set Tire Pressure Check hoses, belts & coolant level check wiper blades & windshield washer fluid level inspect power steering fluid level inspect transmission fluid level inspect front suspension & steering operation rotate tires <u>15k/45k/75k mile service</U> Change Engine Oil & Filter Change Tranny Fluid Replace Fuel Filter Replace Air Filter Inspect Front & rear Pads, Rotor & calipers Inspect all fluid levels adjust parking brake inspect clutch operation, adjust freeplay and check fluid level condition adjust all belts inspect suspension mounting bolts for tightness inspect exhaust system inspect tire wear and set tire pressure check hoses belts and coolant level inspect battery and clean terminals adjust alternator belt inspect valve clearance check wiper blades and winshield washer fluid lube door, hood latches and hinges rotate tire and balance inspect and clean spark plugs inspect cap and rotor road test <u>30k/60k/90k mile service</U> Change Engine Oil & Filter Change Tranny Fluid Replace Fuel Filter Replace Air Filter Replace Spark Plugs Replace Distributor cap, rotor and inspect wires set ignition timing and adjust cambelt Inspect crankcase emissions Inspect front & rear pads, rotors and calipers Replace brake fluid, check hoses & lines adjust parking brake replace clutch fluid, clutch operation, adjust freeplay adjust all belts & inspect power steering fluid inspect suspension mounting bolts for tightness inspect exhaust system inspect tire wear and set tire pressure replace engine coolant & check hoses belts inspect battery and clean terminals adjust alternator belt inspect valve clearance check wiper blades and windshield washer fluid lube door, hood latches and hinges rotate tire and balance [Modified by Soup Nazi, 6:20 PM 7/6/2002] |
Re: FAQ: Acura Recommended Maintenance Schedule (zyg)
This is all in the owners manual, isn't it. |
Cool. Now how about the severe use schedule. http://images.zeroforum.com/smile/emwink.gif http://images.zeroforum.com/smile/emcocktl.gif |
Re: FAQ: Acura Recommended Maintenance Schedule (00-0187)
daym, that's a lot of typing http://images.zeroforum.com/smile/emsmilep.gif
I'll FAQ this when I get to work tomolo http://images.zeroforum.com/smile/emwink.gif yhttp://images.zeroforum.com/smile/emsmileo.gifshi - who just got back from The Block w/ 234 in one piece http://images.zeroforum.com/smile/emsmilep.gif |
Re: FAQ: Acura Recommended Maintenance Schedule (Chris)
no problem http://images.zeroforum.com/smile/emwink.gif
Re: FAQ: Acura Recommended Maintenance Schedule (Soup Nazi)
Re: FAQ: Acura Recommended Maintenance Schedule (Jsracingintegra)
Thanks I'm printing that and stapling it up in my garage.
Re: FAQ: Acura Recommended Maintenance Schedule (2kbill)
way to help out the lazy asses http://images.zeroforum.com/smile/emthup.gif
Re: FAQ: Acura Recommended Maintenance Schedule (RealTypeR)
Re: FAQ: Acura Recommended Maintenance Schedule (Zygspeed)
way to help out the lazy asses http://images.zeroforum.com/smile/emthup.gif LOL! http://images.zeroforum.com/smile/emsmilep.gif I don't see the clean and lube of the antenna. |
Page 129 of my 97 Owner's Manual lists "Clean antenna mast" under the severe condition maintenance schedule @ 15 K mile increments.
Other than that, you've pretty muche covered everything else. http://images.zeroforum.com/smile/emthup.gif P.S. -- Oddly enough it also says that Canadian owners should follow the severe maint. schedule. |
Re: FAQ: Acura Recommended Maintenance Schedule (George Knighton)
thanks man, i appreciate your work http://images.zeroforum.com/smile/emsmile.gif http://images.zeroforum.com/smile/emthup.gif
<u>15k/45k/75k mile service</U> Change Tranny Fluid |
Re: FAQ: Acura Recommended Maintenance Schedule (stormywaters)
I'd never thought i'd see this thread brought up again.
if you have the rear spare jack in the car, you can change the tranny fluid. |
I'd never thought i'd see this thread brought up again. if you have the rear spare jack in the car, you can change the tranny fluid. well... i do have the rear spare jack, so i guess i can do it myself. what size tool do i need? any tricks i need to know? how much honda tranny fluid do i need to pick up? [Modified by stormywaters, 3:36 AM 3/2/2003] |
1 liter will do.
do a search, lots of times this has been put up. basically theres a drain/fill plug. i think they are 19/17mm respectively, but with my forgetful mind, better look it up. torque wrench, and a tube/funnel to feed the fluid in. thats it. if you dont feel confident doing this, just goto the dealer and have them do it. its a no brainer, but some people arent cut out for even this sort of work. good luck. i believe theres a page on c-speedracing.com that covers this. [Modified by Soup Nazi, 10:56 PM 3/1/2003] edit: (one year later) : i cant believe i said 1 liter....prolly closer to 2-2.2 quarts https://honda-tech.com/forums/images...s/emsmileo.gif Modified by Soup Nazi at 12:50 AM 1/26/2004 Modified by Soup Nazi at 12:51 AM 1/26/2004 |
wow, OLD thread.
Tranny fluid change is so easy, even I can do it. https://honda-tech.com/forums/images...s/emsmilep.gif Check out the 'how-to' section on c-speedracing.com like Master Soup said. BTW - is/are the c-speedracing person/persons on h-t?? |
Re: FAQ: Acura Recommended Maintenance Schedule (Chris N)
i dont know, but one of their supposid project cars is on egay for sale!
