Engine Trouble codes
Old Oct 1, 2004 | 09:21 PM
ITR.#1446's Avatar
Default Engine Trouble codes
Went to the track tonight and missed 4th and my motor is shot now....sounds like some bent valves and stuff : but i threw the scanner on and got p0303(it said cylinder 3 misfire), p0420(catalyst malfunction), and p1399 but i cant find out what code that is
Old Oct 2, 2004 | 01:37 AM
b19coupe's Avatar
Default Re: Engine Trouble codes (ITR.#1446)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">Went to the track tonight and missed 4th and my motor is shot now....sounds like some bent valves and stuff : but i threw the scanner on and got p0303(it said cylinder 3 misfire), p0420(catalyst malfunction), and p1399 but i cant find out what code that is </TD></TR></TABLE>
Code # P1399 = misshift owns joo
I looked on H-T for your code but no luck.
https://honda-tech.com/zerothread?id=978933
https://honda-tech.com/zerothread?id=682412
Good lists. I can look in the service manual today and see if P1399 is a valid code. I feel you on your misshift, been there, done that
Old Oct 2, 2004 | 04:18 AM
Chris F's Avatar
Only a boob would mishift! Just kidding there seem to be a lot of mis-shifting stories around here. Fortunately mine (from years ago) had an uneventful ending (3rd-&gt;2nd).
I don't know what that code is, but I'm not sure it really matters. There's no code for "hole-in-piston, valve-in-oilpan".
Old Oct 2, 2004 | 04:30 AM
len's Avatar
len
The closest thing I found was DTC P0139: Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Slow Response
Old Oct 2, 2004 | 04:35 AM
len's Avatar
len
Ok, something real close to your problems:
DTC P1336: Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
DTC P1337: Engine Speed (RPM) Fluctuation Sensor No Signal
Old Oct 2, 2004 | 04:52 AM
Chris F's Avatar
Default Re: Engine Trouble codes (len)
No, wait I found it.
DTC P1399 - Hole in Piston (HP) Valve in Oil Pan (VOP)
p.s. google came up empty except for someone saying it isn't a Honda ECU code. It was seen when the engine was misfiring.
http://www.automotiveforums.com/t195579.html
Old Oct 2, 2004 | 01:23 PM
ITR.#1446's Avatar
Default Re: Engine Trouble codes (ccfries)
Thanks for all the info guys...im going to do a compression test in a little bit to see how it is and ill let you know the #'s but i think im gonna have to start tearing the motor apart....it runs and has power cause i had to drive it home from the track cause no tow truck would drive it but sounds like ****(the exhaust sounds like a wrx its wierd). The p1399 code came up and said pending next to it and i still cant find what it is this really sucks
Modified by ITR.#1446 at 10:52 PM 10/2/2004
Old Oct 2, 2004 | 02:23 PM
ITR.#1446's Avatar
Did the compression test, about a month ago when i did it i had about 220 all the way across give or take now i have this...
cylinder #1 220 #2 180 #3 50 #4 185
this is not looking good
Old Oct 2, 2004 | 09:09 PM
ITR.#1446's Avatar
so me and my buddy pulled my head off in like two hours and the pistons look fine but the valves look a little shitty so thats good...now its time to rebuild the head
Old Oct 3, 2004 | 04:11 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">so me and my buddy pulled my head off in like two hours and the pistons look fine but the valves look a little shitty so thats good...now its time to rebuild the head </TD></TR></TABLE>
Could be worse! Sounds like good news to me. Let us know how the rebuild goes.
Did you have any transmission-related mods? Short shifter? Lightened flywheel? Grippy clutch?
The one time I did mis-shift, it was on all OEM parts and had time to put the clutch in before anything really bad happened. I went from 3rd to 2nd gear.
-Chris
Old Oct 3, 2004 | 08:50 PM
ITR.#1446's Avatar
I have a short throw and had a skunk 2 shift **** on, stock clutch and flywheel and ill keep you guys updated on the build, it should come out very good
Old Oct 4, 2004 | 12:31 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">I have a short throw and had a skunk 2 shift **** on, stock clutch and flywheel and ill keep you guys updated on the build, it should come out very good </TD></TR></TABLE>
You're not the first with a short-throw shifter to have this happen (although stock shifters do the same). What about cams (and cam timing?) I wonder if a more aggressive cam would cause damage to be more likely?
Old Oct 4, 2004 | 05:42 PM
ITR.#1446's Avatar
I ran with completely stock motor, advanced timing to 19 degrees, full exhaust, intake, throttle body and fpr.
Old Oct 4, 2004 | 05:55 PM
RTW DC2R's Avatar
damn Brian sorry to hear!!
Good luck on the rebuild
Old Oct 4, 2004 | 07:44 PM
Chris F's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">damn Brian sorry to hear!!
Good luck on the rebuild </TD></TR></TABLE>
Totally!
Old Oct 4, 2004 | 10:23 PM
ITR.#1446's Avatar
Default Re: (ccfries)
yeah the rebuild should be fun im doin some searching and trying to find what a good turbo setup would be...if anyone has some info let me know i wouldnt want to go through all this again
Old Apr 5, 2005 | 03:46 PM
Lucky-R's Avatar
Default Re: (ITR.#1446)
yikes, that sounds painful. did you miss 4th and straight back to 2nd? good luck bro
IOSUA
11
Aug 9, 2007 08:32 PM
Quickridez_3
Dec 16, 2006 05:02 PM
drumminforev
25
Nov 11, 2006 09:19 PM
Nautical_Star
Honda S2000
12
Sep 21, 2005 07:29 AM
AMG
Sep 2, 2003 07:03 AM
