Engine Light came on, checked it and got code 41?
Old Nov 2, 2002 | 12:49 PM
importadrenelin's Avatar
Default Engine Light came on, checked it and got code 41?
Hey,
My enginel ight was on so I checked the ECU code, the test that they show you to do on C-Speedracing.com Anyways it came up as 41, which is:
Primary Oxygen Sensor - Heater circuit malfunction
So question is where is he primary O2 sensor? and how to replace it?
Old Nov 2, 2002 | 12:51 PM
AccrdATK's Avatar
New User
Default Re: Engine Light came on, checked it and got code 41? (importadrenelin)
primary is on the header.. i believe.. to replace.. go to honda.. or find one in the classifieds.. ask for a o2 sensor... costs a lot brand new.. try to find a used one... there should just be a clip.. just clip off the old one.. screw in the new one or am i wrong.. sorry ive been up 36 hours.. mind is kinda dead rite now
Old Nov 2, 2002 | 02:24 PM
fakemike's Avatar
Default Re: Engine Light came on, checked it and got code 41? (CoreysTypeR)
you may not need a new o2 sensor.
if you do http://www.oxygensensors.com has a good deal for new ones.
Old Nov 2, 2002 | 06:30 PM
JPP's Avatar
JPP
The primary O2 sensor is located under the car, on the end of the header, just before the catalytic converter. To replace it (if needed) you would need a 20 or 21mm wrench (can't remember which) and probably a can of "release all" or WD40.
first you might went to check the wiring or connector for damage.
Old Nov 2, 2002 | 06:40 PM
dicklee's Avatar
Default Re: Engine Light came on, checked it and got code 41? (JPP)
Don't be cheap!!!!!!!!!
Buy the brand new 02 from dealer because 02 directly related to the fuel supply to the engine, also affect the fuel consumption.
Old Nov 3, 2002 | 09:59 AM
juniordc2's Avatar
check the two black terminals on the connector for tightness, those two black wires are your heater circuit. check their resistance, it should be between 15-40 ohms. i had this same problem, and it turned out my resistance was toast, so I bought a new o2 sensor. now i'm getting awesome mileage
Old Nov 3, 2002 | 10:30 AM
xtrafastcivic's Avatar
Default Re: Engine Light came on, checked it and got code 41? (dc2gsr94)
a civic o2 sensor is the same as an integra one... FYI
bigfoot89
Engine Management and Tuning
Dec 21, 2011 05:22 AM
stattonmw
Feb 1, 2006 11:50 PM
samvtecaccordsport
Jul 18, 2004 02:13 PM
SIMATIC
Oct 27, 2003 10:28 PM
Casey
May 16, 2002 08:03 PM
