engine issues
Old Sep 19, 2005 | 12:33 PM
TeayotaSoupra's Avatar
Default engine issues
imagen that...
So on the interstate I notice she's kinda bogging down/sputtering a bit...
Today I pop the hood and see a small leak from one of the top nuts on the valve cover.. I ignore that for a second and pull my #4 wire and inspect it.. looks fine.. Take out the spark plug which is a bit black.. not too bad.. Then I notice a little bit of oil on the ring around the spark plug, sooo I look down into the hole and there is oil on the outside of the cyl where the spark plug goes into but the top looks clean and clear..
So I bang my head a few times and then try to tighten the bolt on the valve cover.. ok so it's loose... or is it? So I try to take it off.. yup not going on or off.. just sitting there spinning.. wtf?? I try pulling up and loosening it.. yea no go..
I guess thats what I get for buying a "Cheap" integra..
Any advice? THe car is mine I can't do anything about that.. No flaming on me rushing the sale.. just help me if you can please!
Old Sep 19, 2005 | 12:52 PM
Mythias's Avatar
Default Re: engine issues (TeayotaSoupra)
Sounds like you have a broken valve cover stud. Not the end of the world.
Old Sep 19, 2005 | 01:02 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: engine issues (Mythias)
The valve cover stud is no big deal. I think your best bet would be to get a compression/leak-down test to better assess the situation.
Old Sep 19, 2005 | 01:03 PM
Dave_B's Avatar
AH hah. THere you are. I've got the stock exhaust for you Nikki if your still interested in trading. Just send me an email or PM me. Sorry to jack your thread.
Old Sep 19, 2005 | 01:07 PM
Default Re: (Dave_B)
hah ok
And it's more than just a broken stud hun
When I start the car the Yellow light on the lower left side.. can't remember what it says.. but yea saying my car is broke lol it blinks for a few seconds after the car is started (all the other lights go off and this one blinks for a bit)
we have the thing to do compression. I guess we'll hook that up tonight.
GOD i'm tired of working on cars..
If I could i'd get a new car..with a warentee..and i'd be the first owner and be able to baby it... I just have expencive taste in cars and can't afford myself
Old Sep 19, 2005 | 01:11 PM
Mythias's Avatar
Default Re: (TeayotaSoupra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote">And it's more than just a broken stud hun </TD></TR></TABLE>
Most likely not. A broken stud could cause oil to seep into the area where the sparkplug is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote"> When I start the car the Yellow light on the lower left side.. can't remember what it says.. but yea saying my car is broke lol it blinks for a few seconds after the car is started (all the other lights go off and this one blinks for a bit)
That's just the service indicator light meaning you are due for a service interval. There is a lil button under the dash near the steering column to reset that. No big deal.
Old Sep 19, 2005 | 01:14 PM
Default Re: (Mythias)
cool.. although the stud is on the other side of the engine... #4 was the only one I pulled.. the bolt is below #1
Old Sep 19, 2005 | 01:22 PM
Oh yea. THe breather that was on the engine.. well thats coverd in oil it's actually black now instead of red..
(so you know what i'm talking about.. yes i know thats a crappy filter on it..
Old Sep 19, 2005 | 01:55 PM
cool guy name
Mythias is right, just the maint req'd light, no big deal. From your pics I cant tell which stud is broken, but again that is not a big deal. As for the filter unless there is oil leaking out of it I wouldnt worry about it. I would still get a check up on that motor.
Old Sep 19, 2005 | 02:44 PM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote">Oh yea. THe breather that was on the engine.. well thats coverd in oil it's actually black now instead of red..</TD></TR></TABLE>
IIRC it's fairly normal for a breather on the valve cover to get oily like that after a while.
BTW, your ground-strap is on the wrong valve cover stud. Where you have it is meant for the JDM throttle cable bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote">cool.. although the stud is on the other side of the engine... #4 was the only one I pulled.. the bolt is below #1</TD></TR></TABLE>
Hmm.. I wouldn't be too terribly worried about it. Do a compression test. If that doesn't turn up anything, when you replace the valve cover stud, replace the o-rings around the holes for the sparkplugs on the valve cover (GASKET B, part# 1234-PG6-000). You may also want to have a spare valve cover gasket laying around in case yours is already damaged, or you damage it during removal (part# 12341-PR3-000).
Old Sep 19, 2005 | 03:06 PM
I just got the car not too long ago.. and the first thing i did was replace the valve cover gasket and the o rings
Old Sep 19, 2005 | 03:28 PM
Mythias's Avatar
It's possible that a few drops of oil dripped down to the plug when you changed the valve cover gasket, or that one o-ring was not installed properly.
Old Sep 20, 2005 | 11:09 AM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote">I just got the car not too long ago.. and the first thing i did was replace the valve cover gasket and the o rings</TD></TR></TABLE>
So its your fault one of the vavle cover studs broke
Old Sep 20, 2005 | 11:54 AM
happy_guy's Avatar
stripped stud, same **** happen to me. its still stripped. seems like your crankcase pressure is too high causing oil to spurt out of that small thing with the filter on it.. maintenance light means you need to change your oil. so when WAS the last time you change your oil?
Old Sep 20, 2005 | 11:59 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (happy_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happy_guy &raquo;</TD></TR><TR><TD CLASS="quote">maintenance light means you need to change your oil</TD></TR></TABLE>
No it doesn't.
Old Sep 20, 2005 | 12:13 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote">GOD i'm tired of working on cars..
If I could i'd get a new car..with a warentee..and i'd be the first owner and be able to baby it.</TD></TR></TABLE>
You could have had a Hyundai!
http://hyundaiusa.com
Jdm_Ego
14
Sep 18, 2010 11:19 AM
Dj Skidz7
Apr 29, 2008 11:16 AM
braass91
14
Apr 27, 2008 12:03 PM
BAZ
Aug 21, 2003 08:46 AM
7rrivera7
Mar 23, 2003 09:25 AM
