Easiest way to fill tranny fluid?
Being that I've had my car over a year, it's the first car I've owned long enough to need a fluid change.
What's the easiest/ quickest way to refill the MTF without a lift? I don't have 4 jackstands to make the car perfectly level, so I'm thinking of just removing the wheel and using one small jackstand if it has any bearing.
I'll probably toss a hose on a funnel but was wondering if the speed sensor trick works on the ITR.
-Matt
-Matt
Re: Easiest way to fill tranny fluid? (Utilitarian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian »</TD></TR><TR><TD CLASS="quote">wondering if the speed sensor trick works on the ITR.
Yes, it works. Probably the fastest way.
Re: Easiest way to fill tranny fluid? (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 »</TD></TR><TR><TD CLASS="quote">just be careful with it...its expensive to replace </TD></TR></TABLE>
and easy to break
and easy to break
Re: Easiest way to fill tranny fluid? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote"><------ Raises hand...
I'll be the dumb guy! You fill it till it starts to over flow correct?
Aloha,
Brandon</TD></TR></TABLE>
over flow FROM THE REGULAR FILL HOLE, NOT THE VSS HOLE. leave the regular fill hole open as you fill and stop filling when it starts to come out of the regular fill hole.
Aloha,
Re: Easiest way to fill tranny fluid? (RTW Ryan)
) but <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan »</TD></TR><TR><TD CLASS="quote">
and easy to break</TD></TR></TABLE>
How's it break (I'm sure I could find a number of ways ), typically speaking.
Does it just pop out after removing a 10mm bolt and plug or something?
remove the 10mm and clean the dirt/dust from around the hole... then twist and lift out.
don't drop it.
don't drop it.
sleepermachanic 8
05-16-2006 07:04 PM
aser1z
09-07-2005 08:17 PM
Mora
09-29-2003 06:58 PM
