tranny fluid change
tranny fluid change
ok so my axle popped out when driving. also im not at home. i fixed the axle problem but i need to add fluid. im going to drain the remaining and refill. give me all the spots you can add fluid into the tranny through. i dont have my long tube and long funnel. only a small funnel. so somewhere on top. thanks
Re: tranny fluid change
if it's a d-series engine you have then you can fill it through the hole for the reverse solenoid. or if you can reach the area with your funnel you can fill it through the hole for the speed sensor.
JENNY_EG6
12
09-25-2009 08:43 AM
aser1z
09-07-2005 08:17 PM
